Stripper chassis screw >
Like Tree1Likes
  • 1 Post By Wanderer77
Old 05-14-2017, 05:17 PM
Trader Rating: 15 (100%+)
Default Stripper chassis screw
Hello all,
I am looking for some help. I have stripped a FHCS screw on the bottom of my chassis..any input on how to get it out?
Since it's sunk in the chassis, I cannot dremel a slot to use a screw driver...
Any input is appreciated!
motoman811 is offline
Old 05-14-2017, 05:25 PM
beidle99's Avatar
Dremel with a small cut off wheel and dont cut the chassis.
beidle99 is offline
Old 05-14-2017, 05:30 PM
You need an appropriately sized ez-out. Will have it out in no time.
Google ez out screw extractor, then head to your local hardware store.
latentspeed likes this.
Wanderer77 is offline
Old 05-14-2017, 05:31 PM
Use drill bits to drill out the head. Once the head is gone and just the threaded shaft remains you can separate the parts and can most likely back out the rest of the threaded shaft with your hands or needle nose pliars.
Haadkoe is offline
Old 05-14-2017, 06:31 PM
JsK
JsK's Avatar
Drill and spring loaded center punch. Drill out the center until its almost
seperated and then use the center punch to seperate it the rest of the way.
You can then pull off whatever part your working on and remove the screw
stub. I have easyouts that work great with 2.5 heads but have yet to find one
that works with 2mm heads.
JsK is offline
Old 05-14-2017, 07:03 PM
What wanderer77 said. Happened to me once. Best way of getting it out without risking chassis damage. Ez out. It's made for removing stripped screws, which is what you have.
latentspeed is offline
Old 05-14-2017, 07:19 PM
werner sline's Avatar
my favorite method too ! use the dremel with a small cutting disc, dig a line in the screw in order to get the screw out with a flat screw driver.
i don't like the drilling method because the rest of the faulty screw will be stucked in the part
werner sline is offline
Old 05-14-2017, 11:34 PM
mustangkillaz's Avatar
Small cutoff wheel and slot it for a screwdriver
mustangkillaz is offline
Old 05-15-2017, 12:45 AM
The screw sounds exotic! Would like some pictures.
nicholasxuu is offline
Old 05-15-2017, 04:48 AM
offroad dude's Avatar
Trader Rating: 31 (100%+)
Use this with a small drill or electric screwdriver and it will come right out with zero issues.
https://www.amazon.com/Alden-4507P-G...s=screw+ez+out
offroad dude is offline
Old 05-15-2017, 05:34 PM
amospetrie's Avatar
Trader Rating: 14 (100%+)
+1
amospetrie is offline
