4wd and 2wd 1/10 scale buggy >
Old 03-19-2017, 08:12 PM
Default 4wd and 2wd 1/10 scale buggy
Are the rear tires the same on both the 4wd and 2wd buggy?
Nspenc6 is offline
Old 03-19-2017, 08:13 PM
EbbTide's Avatar
Trader Rating: 39 (100%+)
Yessir
EbbTide is online now
Old 03-19-2017, 09:14 PM
What about steers?
Nspenc6 is offline
Im thinking about taking into 1/10 scale and dont know much.
Nspenc6 is offline
Old 03-19-2017, 09:18 PM
EbbTide's Avatar
What about steers?
If you mean the front wheels, then the 4wd fronts are a little wider than 2wd front wheels. But depending on the track surface, you can run 2wd front wheels on a 4wd buggy too.
Old 03-19-2017, 09:20 PM
What about 4wd on the front of a 2wd.
Nspenc6 is offline
Old 03-20-2017, 12:05 AM
Super Moderator
Grizzbob's Avatar
Depends on the wheels being used. 1/10 scale 4WD buggies have a couple of options available, some can use the same wheel hexes as 2WD buggies(12mm hexes), but there are also older cars that used(& might still use) 10mm hexes, those would NOT fit on a 2WD buggy's front axles....
Grizzbob is offline
