Traxxas Ruslter back sagging real low. To Low >
Old 03-05-2017, 01:25 PM
Default Traxxas Ruslter back sagging real low. To Low
Hello, Well its been a slow build. Little at a time. my franken (lots of spare pieces) build now has a really low back end that im not sure how to resolve. The shocks were purchased from the site(used). I was told they were traxxas big bore shocks. Once i add the motor Castle Creations 3800KV, the back end drops. How do i correct this?
Attached Thumbnails Traxxas Ruslter back sagging real low. To Low-thumbnail_file.jpg   Traxxas Ruslter back sagging real low. To Low-thumbnail_file1.jpg   Traxxas Ruslter back sagging real low. To Low-thumbnail_file2.jpg   Traxxas Ruslter back sagging real low. To Low-thumbnail_file3.jpg   Traxxas Ruslter back sagging real low. To Low-thumbnail_file4.jpg
rustlervxl is offline
Old 03-05-2017, 03:08 PM
abailey21's Avatar
Trader Rating: 36 (100%+)
Add a collar or two on your rear shocks to bump your ride height up
abailey21 is offline
Old 03-05-2017, 04:52 PM
The collar was already applied. collar=clip above the spring, correct??
Old 03-05-2017, 05:06 PM
hotrod87's Avatar
Trader Rating: 252 (100%+)
Try moving the shocks closer towards the chassis. I've always had to run them with a thick and a middle size spacer on my rustler's to keep them from sagging so bad. Could try a heavier spring if you have some.
hotrod87 is offline
Old 03-05-2017, 05:31 PM
harry697's Avatar
Trader Rating: 118 (100%+)
Did you check to make sure nothing is binding? If not, I would start by removing the rear wheels, then unscrewing the shocks from the a-arms. Then check to make sure the arms fall with no resistance after you raise them. Also, make sure that the shocks pivot freely on the upper mounts at the shock tower. If nothing is binding, either add preload spacers or use a heavier spring.
FWIW, it looks like the springs you're using are for a slash. They'll work, but I would ditch them for some linear springs.
harry697 is offline
Old 03-05-2017, 05:43 PM
abailey21's Avatar
Yes those, and add more. You're not limited to one
Old 03-05-2017, 07:19 PM
tsair's Avatar
You can also throw on some stiffer springs, I think the blue Losi 2.5" rear springs will fit and are stiffer.
tsair is offline
Old 03-05-2017, 08:33 PM
harry697's Avatar
I just looked at your pics again and noticed that it's sagging that much and there isn't even a battery in the truck. Something is definitely not right. My money is on binding in one or more of the hinge pins.
harry697 is offline
Old 03-05-2017, 08:57 PM
hotrod87's Avatar
How long are the rear shocks ? Im wondering if they are the shorter ones ?
hotrod87 is offline
Old 03-06-2017, 04:31 AM
Hello, I just finished putting the rear back together. The orig. hinge pins were bent. I replaced the suspension arms and hinge pins. As for the length of the shocks im not sure as I got them from a parts car. I have to check them tonight when i get home from work. Ill also look to see about replacing the springs. Thanks everyone for your help.
Old 03-08-2017, 05:04 AM
Morning, Well, i took everything apart last night and as I was gettign it back together i noticed that the suspension arms were left/right specific. There was my binding issue. So now that part is corrected. thank you for your feedback
2 additional question. Im going to replace the rear springs on the Traxxas Big bore shocks and well as change out the oil. What are Linear springs and any suggestions on what oil i need to use for the rear shocks. Thanks again.
Old 03-10-2017, 04:19 AM
2 additional questions:
Old 03-10-2017, 04:25 AM
hotrod87's Avatar
I've always preferred the progressive springs and 35 to 40 weight oil. The stock rustler springs are linear.
hotrod87 is offline
Old 03-10-2017, 04:29 AM
hello, Any specific "progressive" replacement springs i should look for? Id like to keep the Big bore shocks and swap out the springs.
Old 03-14-2017, 03:59 AM
Morning, Any specific "progressive" replacement springs i should look for? Id like to keep the Big bore shocks and swap out the springs.
