Like Tree463Likes
TLR 22 4.0
    Hide Wikipost
Old 03-22-2017, 06:19 AM   -   Wikipost
R/C Tech ForumsThread Wiki: TLR 22 4.0
Last edit by: Matt M.
22-4.0 Wiki
Print Wikipost
Old 03-09-2017, 07:45 AM
  #91
thecman26's Avatar
Trader Rating: 100 (100%+)
Originally Posted by Jamie James View Post
#thisguyshouldhavetheofficialthread
true that
thecman26 is offline
Old 03-09-2017, 08:12 AM
  #92
Frank,
Are the 4.0 front & rears arms the same as the 3.0 (except for the hole on the front of the rears?) Is the 4.0 front shock tower the same as the 3.0?
BK24 is offline
Old 03-09-2017, 08:24 AM
  #93
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
Originally Posted by BK24 View Post
Frank,
Yes, you can run the 4.0 arms (stiffezel) on the 3.0.
Yes, front shock tower has not been changed.
oxygen and BK24 like this.
Frank Root is offline
Old 03-09-2017, 09:07 AM
  #94
Now that the 4.0 has some carpet specific features, will tlr ever release a slim/narrow wheel so tlr drivers won't have to trim the standard 2.2 wheels?? Between Schumacher & JC, I believe every other brand of buggy has a slim wheel that fits(offset, etc) ...except TLR. Seems like a glaring omission that can't be THAT hard to manufacture, but maybe I'm wrong...
Is TLR43011 considered a slim wheel? I'm not sure what a 61mm wheel is used for?
BK24 is offline
Old 03-09-2017, 09:33 AM
  #95
rayzcar's Avatar
Trader Rating: 23 (100%+)
That one got me for awhile too. The 2.4inch/60mm/61mm/Evo wheels have more to do with the diameter of the wheel (compared to standard 2.2" diameter wheels) which requires different inserts and tires. Supposed to be lighter weight and more responsive steering since thinner sidewalls (overall diameter is the same). In full size world, it's like a Plus+1, larger wheel with lower aspect ratio or profile, therefore same overall diameter which doesn't make your speedometer read way off. I think slimmer wheel has to do with overall width of the tire/wheel (again, full size world example would be 245mm versus 265mm at beginning of tire size). For visual, find picture of competitor cars from release back in June 2016 and compare front wheels between dirt and non-dirt version.
Here's a nice explanation on JConcepts site: http://www.jconcepts.net/garage/proj...vs-60mm-wheels Tire beads and mounting is different as well.
rayzcar is offline
Old 03-09-2017, 12:40 PM
  #96
It's just a different mounting style, but no it isn't a "slim" wheel like for carpet.
electrickid is offline
Old 03-11-2017, 07:52 AM
  #97
brad996's Avatar
Frank Is there a rear sway bar in the works. would really help on carpet
brad996 is offline
Old 03-11-2017, 11:29 AM
  #98
TLRacing
Frank Root's Avatar
Yes, front and rear sets will be coming when the 22 4.0's do, or shortly after.
charvel74 likes this.
Old 03-11-2017, 11:14 PM
  #99
Not sure if this has been asked yet... But will the gear diff for a 3.0 Drop right into the 4.0?
raym5590 is offline
Old 03-11-2017, 11:18 PM
  #100
TLRacing
Frank Root's Avatar
For sure.
Old 03-12-2017, 11:00 AM
  #101
Joel Lagace's Avatar
when will the manual be available? So i can virtually build one
Joel Lagace is offline
Old 03-12-2017, 05:49 PM
  #102
thecman26's Avatar
I would say the 4.0 is a very competitive buggy with Dakotah winning mod buggy this weekend with a tough field of very talented drivers present! Lay down on a med bite track is a winner!
Old 03-13-2017, 09:09 AM
  #103
TLRacing
Frank Root's Avatar
Working on it
Old 03-13-2017, 10:23 AM
  #104
Agreed, excited to get one soon.
achtung1970 is offline
Old 03-13-2017, 07:23 PM
  #105
Default Carpet Question...
I cannot find any real information about the Aluminum Diff (TLR332067). Is this a good upgrade for a mod (6.5 motor) carpet TLR 22 or is this piece for the TLR 22SR?
Thank you,
Glenn
glennmathias is offline
