Like Tree478Likes
TLR 22 4.0
    Hide Wikipost
Old 03-22-2017, 06:19 AM   -   Wikipost
R/C Tech ForumsThread Wiki: TLR 22 4.0
Last edit by: Matt M.
22-4.0 Wiki
Print Wikipost
Old 06-01-2017, 07:21 AM
  #676
thirtydaZe's Avatar
Trader Rating: 39 (100%+)
Originally Posted by SickNT760
I am running the Exotek with the laydown installed. The fan will be behind the motor with an angle still providing plenty of air flow. These are two pics that I have right now. If you want I can snap some more pics when I am at the track tomorrow.
Thanks for the pics. I have my car apart right now, so I'll give this a shot. after all my getting pist off i'm not sure i tried to mount from the bottom.
thirtydaZe is offline
Old 06-01-2017, 09:48 AM
  #677
Originally Posted by thirtydaZe
What fan mount is everyone using for your motor? Bought an exotek and must be over thinking it, but cant get the thing to fit with any direct shot to the motor.
Anyone got pics or a better option for me?
MIP tape seems to work for me.
thirtydaZe likes this.
Micah123 is offline
Old 06-01-2017, 01:24 PM
  #678
Originally Posted by jmitchell
Double check the transmission inserts are in the correct position. I had this same thing happen to my 4.0 after I first built it, turns out I put the tranny inserts in upside down.
They are in correct position. I have gone to 28.5 mm on my rear shock stroke assuming the drives may have snagged since they were pretty close to the ends of the outdrives. Also thinking the outdrives rings may have caused the sound as they seated or moved on the outdrives at it spun. At this point, who knows. Car running fine so probably all is good. I am leveling rear arms now whenever I break in my diff just in case.
Micah123 is offline
Old 06-01-2017, 07:49 PM
  #679
mourinho's Avatar
Trader Rating: 46 (100%+)
step A2 of the manual, is it calling for the steering servo to be off-centre? or is it just a reminder to centre? i read it at as "build off-centre" which makes no sense to me
mourinho is offline
Old 06-01-2017, 07:54 PM
  #680
Yes, it should be slightly off. Plug your servo in and center it, then mount the servo arm at a slight angle as shown.
Callaway is offline
Old 06-01-2017, 08:01 PM
  #681
Trader Rating: 25 (100%+)
All the servo's i have used will not allow you to center the horn. It's always slightly off one tooth angled inward.
chevmaro is offline
Old 06-01-2017, 08:05 PM
  #682
mourinho's Avatar
then the steering links are uneven length in order to have equal toe..
mourinho is offline
Old 06-01-2017, 08:06 PM
  #683
mourinho's Avatar
thats what sub-trim is for
mourinho is offline
Old 06-01-2017, 08:15 PM
  #684
tsair's Avatar
No, steering links need to be the same. Servo horn should be at approximately 1 o'clock position. If necessary, adjust the length of the drag link, but if you installed everything else correctly (servo, horn, steering links), it should be pretty close. If your servo is spaced too far forward/back, your drag link length will be wrong.
tsair is offline
Old 06-01-2017, 08:51 PM
  #685
What tsair said, and...
I used servo shim to get servo link horizontal. 1-2mm gap on the servo link, doesn't have to be perfect.
Measure steering turnbuckles per the manual, it will set you up even.
Install servo horn one tooth inward,
Trim out the rest. EPA is about even at 80% with full throw both directions. Sub trim is about 10 on my airtronics.
chevmaro is offline
Old 06-02-2017, 03:12 AM
  #686
No. Just build according to the manual like we are saying and you'll see. I have built five 22-series kits and rebuilt two more... it works out.
Callaway is offline
Old 06-02-2017, 03:48 AM
  #687
mourinho's Avatar
Im not doubting that it has worked out for you and others, but for me there is no way it will work with even length links.
I have already built the car and set the steering and the only way it will work is with horn centered. Ive had it all apart and double checked everything and its built correctly.
I am using the aluminium steering rack and posts so im not sure if that would be causing this?
mourinho is offline
Old 06-02-2017, 08:24 AM
  #688
F N CUDA's Avatar
Trader Rating: 34 (100%+)
another reason to adjust with the drag link instead is to prevent the link from going into an over extension where the servo arm travels too far, pointing down and then the link will dog leg the wrong way and lock
F N CUDA is offline
Old 06-02-2017, 08:25 AM
  #689
jnslprd's Avatar
As long as you have full steering in both directions and the car tracks straight after sub trimming, it won't matter either way. You are only using part of the servo travel and have to limit it in both directions anyway, with EPA.
jpcopeland1 and Callaway like this.
jnslprd is offline
Old 06-02-2017, 09:41 AM
  #690
Trader Rating: 166 (100%+)
What the guy above said.
jpcopeland1 is offline
