Like Tree478Likes
TLR 22 4.0
    Hide Wikipost
Old 03-22-2017, 06:19 AM   -   Wikipost
R/C Tech ForumsThread Wiki: TLR 22 4.0
Last edit by: Matt M.
22-4.0 Wiki
Print Wikipost
Old 03-12-2018, 07:49 PM
  #2236
Default 22 3.0 and 22 4.0 for loose dirt track
Thinking of getting the 22 4.0.however, asides to the chassis and lay down gear box, it seems to be most of the
parts are similar with the 22 3.0 - assuming I will be running 3 gears stand up. Please kindly help to enlighten me. Thanks
David_Lim is offline
Old 03-13-2018, 09:14 AM
  #2237
Trader Rating: 28 (100%+)
David,
You are correct, it shares most of the same parts with the 3.0 however the chasis is different, laydown gear box, body and the material of the arms/rear tower is harder. If you have a 3.o already running standup I don't think it will be much different. All the same parts except the new spindles are included in the 4.0.
However if your getting a new car, the 4.0 would be the way to go as you get both the laydown and standup version in the same box.(think it is only original 4.0 and not the sr version). Converting would be costly if you were to make a 3.0 to a 4.0 with all the parts.
dbracn is offline
Old 03-13-2018, 10:03 AM
  #2238
Originally Posted by dbracn
David,
Thanks Bro for the advices
Old 03-13-2018, 10:54 AM
  #2239
rvrslt1's Avatar
Trader Rating: 35 (100%+)
Any word on a new car? I know AE will have the .1 out soon and the Yokomo may also have one. A number of guys at OCRC seem to be changing or going away from the TLR? If Yokomo had more than 350 something world cars even more TLR's would be on here for sale.
I really enjoy driving my TLR but would not mind building something new.
5Whitts likes this.
rvrslt1 is offline
Old 03-13-2018, 10:56 AM
  #2240
AJH387's Avatar
Ya, like you said, just the normal 4.0. SR just laydown.
AJH387 is offline
Old 03-13-2018, 04:33 PM
  #2241
Originally Posted by westkoast661
Just switched to the TLR 22 4.0 after years of running AE. Is there ANY way possible I can run AE wheels on the FRONT of the 22? I really donít wanna start new buying wheels. I have waaay to many AE wheels
Thanks in advance
Put all the shims on the outside of the hub and add a small washer between the hex and wheel, for the rear use a A&E 7.0 mm or wider, I use 8.5, plastic hex and just bore it out with a drill of the same size as the axle
Slashripper is offline
Old 03-13-2018, 05:45 PM
  #2242
Thanks for the info because I just picked one up and have all ae wheels too thanks
billsharp34 is offline
Old 03-13-2018, 07:30 PM
  #2243
Suspended
If you are saying shim the front hex out to fit ae front wheels to a 22, that will not work. The ae wheels already make the car too wide. Aside from being too wide, it also induces weight jacking because of the increase in scrub radius. Find someone selling a 22 with extra tires on here. Offer to buy a few sets of fronts for $25.
You can do that to run 22 wheels on an ae car, but you can't go the other way.
urnotevenwrg2 is offline
Old 03-13-2018, 08:01 PM
  #2244
Originally Posted by skoalisbad4me
Iíve never had a single ball cup pop off and I have thousands of laps on my 4.0sr
I have a 22 4.0 SR and I havenít popped a ball cup yet and Iíve took some nasty spills lol
AJH387 likes this.
JHerbel is offline
Old 03-13-2018, 09:28 PM
  #2245
Ike
Ike's Avatar
Originally Posted by Phugazi
Just got a set of those in the mail and mounted up some low profile Cut Staggers...fit great! Ran same tires with Schumacher slim wheels on my B6 so was excited DE made slims for the 22 4.0. I also run them not glued and never had a issue.
Thanks! Making me wish I hadn't changed my mind and gotten white...
Ike is offline
Old 03-14-2018, 10:47 AM
  #2246
Originally Posted by mark-rc
What effect will running the axle spacers do to the handling of the 22 4.0?
Iím wondering the same thing. Is it just used when you run 67mm bones with the tranny set to +3.5 or can you run them for both 0 and +3.5 where do you put the shim also? The manual doesnít show.
JHerbel is offline
Old 03-14-2018, 06:11 PM
  #2247
I'm planning to buy a 4.0 SR to race on black carpet and astro. Other than the gear diff, springs and anti roll bars, is there anything else I should plan to order?
JeffC is offline
Old 03-14-2018, 08:09 PM
  #2248
AZJP's Avatar
Trader Rating: 21 (100%+)
Regular 4.0 Driveshafts, axles for regular 4.0 driveshafts, HRC front pivot, +3 hubs and weight plates. Better off buying a regular 4.0 and a lockout, if that’s what you’re after.
AZJP is offline
Old 03-14-2018, 09:09 PM
  #2249
Team Pink's Avatar
Trader Rating: 20 (100%+)
+1 to AZJP. Definitely go with the regular 4.0. Everything you need comes in that kit minus the gear diff and swaybars.
Team Pink is offline
Old 03-14-2018, 09:23 PM
  #2250
I thought the SR was the same thing but lighter drivetrain components and no stand up gearbox. I guess I'm just confused why the standard would be preferred. Please help me understand.
BTW, this is for 17.5 on carpet/turf.
JeffC is offline
