Like Tree464Likes
TLR 22 4.0
    Hide Wikipost
Old 03-22-2017, 06:19 AM   -   Wikipost
R/C Tech ForumsThread Wiki: TLR 22 4.0
Last edit by: Matt M.
22-4.0 Wiki
Print Wikipost
Old 10-09-2017, 06:45 PM
  #1516
Trader Rating: 21 (100%+)
Originally Posted by HeavyD99 View Post
It will be interesting to watch the 4.0 at the IOCC this week in Las Vegas. I'm not sure if it's the buggies themselves designed more for dirt and clay or a lack of market share or access to the actual products, but TLR buggies don't seem to be popular in the EOS series and I'm keen to see how they fair at this race in the hands of North American Pro's. Xray, Yokomo and Schumacher have more experience on carpet, and AE have a nice copy of the Yok and great drivers, it'll be an important event for TLR to showcase their buggies.
The EOS has a spec tire and rim. TLR runs a different offset front wheel and does not work.
HeavyD99 and MrLean like this.
Brian L is offline
Old 10-09-2017, 07:29 PM
  #1517
Losi Chaser's Avatar
Originally Posted by jpp2422 View Post
So here is a new one for me. Just finishing up my 22 4.0 build. Spur and pinion move / spin when power is applied but rear axles / drivetrain/ wheels don't budge. They spin freely when moved by hand etc so they are not bound up. So far I have...
1.Rebuilt the diff twice. Each time all gears move / spur moves the rear diff, but when the gear box is installed back on the buggy it goes back to not moving when the spur gear is spun.
2. Gone from very tight to very loose slipper. no change
3. Gone from very tight to very loose diff screw. no change
Any ideas? Thanks!
JP
diff or idler inserts not matched correctly? Diff in clay position, idler in +3 position.
Losi Chaser is offline
Old 10-09-2017, 08:15 PM
  #1518
Jtipsy's Avatar
Any ideas? Thanks!
JP
Make sure you put the screws in the right spot had a buddy put screws in wrong locations and it dimpled the case had to shave them out.
Jtipsy is offline
Old 10-10-2017, 08:47 AM
  #1519
Working on finishing up my 4.0-Spec Racer build. I race 17.5 stock on astro turf at my local track. Noticed that the Spec Racer manual stock setup sheet is somewhat different than the 4.0 Carpet/Astro setup sheet. For example, 4.0 manual has a ride height of 16mm while the 4.0SR has 23mm. So which manual setup sheet should I follow for stock astro racing, 4.0 or 4.0SR?
Phugazi is offline
Old 10-10-2017, 09:41 AM
  #1520
Originally Posted by Frank Root View Post
Frank, is there a set up posted from that Denver race?
Dale.0 is offline
Old 10-10-2017, 09:49 AM
  #1521
The 4.0 astro setup is $$$$
MrLean is offline
Old 10-10-2017, 10:50 AM
  #1522
Okay, good to know...thank you!
Phugazi is offline
Old 10-10-2017, 11:01 AM
  #1523
JAE
Trader Rating: 30 (100%+)
What's everyone running for trail inserts. Tried 2 trail with 2 Ackerman plates and has a ton of steering. A little too twitchy. However on my clay car I recall the 3 trail setting to be barely enough and had to use the 1 Ackerman plate. But that's clay. What's everyone using for trail on carpet?
JAE is offline
Old 10-10-2017, 10:02 PM
  #1524
Trader Rating: 15 (100%+)
Looking for more forward bite on a dry and slick/glazed clay track. Would it be good to lower antisquat or to try running standard parts instead of stiffezell? Any other ideas?
dbracn is offline
Old 10-10-2017, 11:00 PM
  #1525
I haven't tried it but read on here that people have good results by moving the rear hubs forwards.
Pistol123 is offline
Old 10-11-2017, 04:24 AM
  #1526
Trader Rating: 22 (100%+)
Run the non-stiffezell rear arms and 1* antisquat.
Tanis103 likes this.
RandyJones is offline
Old 10-11-2017, 02:32 PM
  #1527
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
Dakotah's Setup from the outdoor TLR Cup at MHOR:
http://www.tlracing.com/ProdInfo/Fil...2017_09_30.pdf
Frank Root is offline
Old 10-11-2017, 04:58 PM
  #1528
tony montana's Avatar
Trader Rating: 71 (100%+)
Frank has any of the team guys posted any setups for the nats?
tony montana is offline
Old 10-11-2017, 06:53 PM
  #1529
Tanis103's Avatar
When I need more forward bite I went to 1.5 anti-squat and 3.5 toe inserts from normal setup of 2 anti-squat and 3 toe inserts.
Ed
Tanis103 is offline
Old 10-11-2017, 07:00 PM
  #1530
Originally Posted by Tanis103 View Post
When I need more forward bite I went to 1.5 anti-squat and 2.5 toe inserts from normal setup of 2 anti-squat and 3 toe inserts.
Ed
less rear toe gives you less forward bite
shark2288 is offline
