TLR 22 complete aluminum gear diff
Unless I'm mistaken this is a new release by TLR. The part #is tlr332067. Looks like the entire assembly is aluminum including the gears. I'd like to hear peoples thoughts on this. I have a 22sct 2.0 waiting to be built. I already have the aluminum idler and had planned on getting the rtr gear diff to cut down on maintenance. The new aluminum diff is over double the cost of fhe plastic unit. I'm trying to decide if I'd be better off getting all aluminum, or if it would be a waste of $. I'm leaning toward the aluminum, but am undecided. Thanks in advance for any opinions.
Thanks for the response. That's exactly the kind of info I was looking for. I'll give one a try. If it's even a small amount smoother and seals only a little better that helps justify the cost. I can't even see it, so it needs to do something for over double the $ . It'd be nice to find a deal on one, but being a new part that's unlikely.
Racing? Go with the new piece. I tried the RTR diff for carpet and switched to the Serpent gear diff. But raced last week with the new TLR one and it's great.
Bashing? Save money and get the RTR diff.
The new one wouldn't leak anyway. That RTR diff was horrible. The Serpent wouldn't leak no matter how thin you went. Yes, thicker oil won't leak as easily, but that wasn't the reason the RTR diff leaked. It was just a bad design. Not to mention it was very notchy. It's very telling that the original diff was a Losi part (meant for RTR and just grease to be used). It was long past time for TLR to come out with a diff... and it is a good one!
I use the RTR diff in my 22 3.0 buggy and it seems a bit notchy. Also the RTR diff is quite a bit heavier than the ball diff so i assume that this aluminum gear diff will solve the problem of added drag from the weight alone.
Anyone have one they can weigh?
I just started with 30k in my stock buggy. Wasn't diffing out on that track. I've been in dirt mode since, so I haven't tried anything else. Go to the 22 3.0 buggy thread and ask, maybe someone there has some better input.
We run on high bite carpet. I started off with the 30k that came in the kit. Car had great rotation. When I was running the rtr diff usually ran 7k. The new diff feels better but has some gear whine since it is all the internal gears aluminum now, since I switched to the laydown setup.
Ball diff - 31.7 grams
RTR Gear- 37.1 grams
New aluminum Gear- 32.2 grams
You should put some grease in your transmission, because I have heard of the diff being chipped with the aluminium idler gear
