Goolrc 120amp issues
Hooked up to smc 4500kv sensored motor wont run but for a min or so then goes off resets and comes back on and repeats, tried new battery, adding a bec , used program card to disable lipo cutoff, doesnt change. Is 40 degrees outside so not getting hot. Gearing is stock.
Are you running a sensor cable? Try running sensorless ?
Is it the 550 or 4 pole motor meant for short course trucks?
