Old 01-14-2006, 01:51 PM   #1
Default Tires
Well, please post any questions or comments about tires, compounds, inserts, rims, etc.
I'll start
Is tread pattern part that touches the insert the same on all Losi tires specifically the taper pins (pinks) and X-2000's (pinks) for 10th scale buggies?
Vahe is offline   Reply With Quote
Old 01-14-2006, 04:08 PM   #2
mafiaracers's Avatar
Trader Rating: 22 (100%+)
Send a message via AIM to mafiaracers Send a message via MSN to mafiaracers
A lot of Losi tires have tread on the inside of the tire. I've never known the scientific reason for this, however, I've always thought of it as tread for the foam. The rubber can grip the foam better, but then again, I don't know how this would help. Lately, I've been using spray glue to glue the foam to the rim. It makes the tire more consistant in roll and traction wise.
That's my input.
Chris Woods
MAFIA MOTORSPORTS
http://www.rctech.net/forum/r-c-items-sale-trade/168239-pit-board.html
TEAM WAVE
www.teamwaveonline.com
TQ Racing Wire
www.tqracing.com
mafiaracers is offline   Reply With Quote
Old 01-14-2006, 04:23 PM   #3
backyardMT's Avatar
Send a message via AIM to backyardMT
do you guys think foam is a necessity for tires? does it really help that much?
backyardMT is offline   Reply With Quote
Old 01-14-2006, 05:58 PM   #4
Timmy Heiser's Avatar
If you didn't have foam in the tire it would be like running on a flat tire. Unles you are talking about tires for a Monster truck, which i think are strong enough to not need foam. But I'm not 100% sure.
Timmy Heiser is offline   Reply With Quote
Old 01-14-2006, 06:18 PM   #5
tires are give or take 85+% of your setup. Compound, pattern and insert are crutial to a good setup and well handeling car. Generally though, unless you're running offroad on a track that allows for slicks, you'll be using the stock foam. But, be sure to get your compound correct!
Another thing is, experiment with foam forming. Cut the foam edges to fit the tire inner tire better. This will allow the foam to conform to the tire wall better and allow for a more consistant feel.
Chris Woods
MAFIA MOTORSPORTS
TEAM WAVE
TQ Racing Wire
www.tqracing.com
Cleaning Out Garage Sale TIRES TIRES TIRES MattOCM R/C Items: For Sale/Trade 5 01-15-2008 03:55 PM
Foam Tires, Parma, TRC, JACO, Tire truer, Rubbers tires and much much more! Team Speedy R/C Items: For Sale/Trade 43 12-15-2006 10:38 AM
Team Orion tires / monster truck tires and weld wheels evostyle R/C Items: For Sale/Trade 4 04-25-2006 09:52 PM
TIRES tires TIres, Ellegi or UFRA. bleach1 Nitro On-Road 51 06-01-2004 10:58 PM
Used trc & jaco touring & 12th scale tires trued mint shape a ton of tires 1 to 3 run jason cheng R/C Items: For Sale/Trade 10 01-02-2004 10:27 AM
