Tekno RC EB410 Thread
#3511
I'm assuming you are running at SDRC and from what I've been told most there are running a 24/25 pinion with the 81 if they have the spec r 13.5. Talk to the guys at the counter, or anyone there, they are pretty helpful. I'll be running the same setup when the motor is back in stock.
#3512
Ok with MYLAPS, which is the one to get ? I have seen different wire types,and colors red or a black. I’m sure it has been answered here, was hoping to not have to speed read 234 pages though.
#3513
If the rear is coming out on throttle I'd suggest you go back to a center diff. If you're really adamant about running a slipper then I would say try a either a higher rear roll center or a little bit more antisquat. Both of those will affect your off power handling as well so be prepared for that.
I also ordered the weight option pack to the exotek weight (2x8 gram) to see If this also makes the rear to hold on better.
Going back to center diff is not an option for carpet.
#3514
The hybrid or ‘two wire’ will work everywhere where as the 3 wire will not work where tracks have not updated their systems in awhile. I think most have updated where the 3 wire will work and knowing my laps they will eventually phase out the hybrid and go only the 3 wire.
#3516
Tech Legend
Had a great showing with the EB410. did some setup changes with the Bush setup, few things kept from my old setup (namely front and rear diff settings) and it worked, great. Managed to TQ and take 4wd buggy mod class running spec power.
I added in exotek weight full and the Exotek fork and rear carriers. The Exotek Diff fork with the schelle slipper had slight play, so watch for that, may 1 or 2 shims will clear that up.
Funny side note, running SCT 4x4 class took that one 2 and about half way in had blown the top of a rear shock clean off the shock mount, so managed to still pull off the win like that lol.
#3517
Bro,you look like the unhappiest EB410 driver ever man. Smile lol,but congrats on 1st
#3523
The diffs are 5k and 7k and I think the oil is like 35..
#3524
Do yourself a favor and get the aluminum shock caps and either the TLR spacers for the bottom shock cartridge or the new set from MIP. HUGE difference in performance and seal that way. No more bleeding each pack to stay consistent and replacing oil every few days of running.
http://site.petitrc.com/setup/tekno/...regon20171015/
