Tekno RC EB410 Thread
#3361
Hello Everyone, we released a recommended indoor (clay) setup for the EB410. Be sure to follow the entire setup and yes the diff oils are a bit odd, but it works very well!
#3362
#3363
"Lunsford stuff is expensive for a reason" your right...they want to make money, I just don't feel like giving them my money when I can have the same for less.
#3364
2 Days of testing now on high grip carpet with the longer rear brace on. No bulk breakage. Put 3 washers in the rear for better roll center and It was a huge difference. The car sweeps corners real well now.
The only thing I noticed was that the Raceform front tower began to feel a little bit swampy in the plastic so I went back for the cf Tower i had Before. Much better feeling in the car after this.
I want to change the ball cups and turnbuckles to Associated parts. Anyone know what parts number I should use to have the correct ones?
#3365
https://www.amainhobbies.com/team-as...c91453/p275225
I run these with the Lundsford Ti turnbuckle kit.
#3366
#3367
#3368
Those b5m ballcups fit on stock ballstud?
#3370
They should. The AE ballstuds are the same width as the Tekno studs. I have the AE ballcups but I haven't made the switch as the stock rod ends have held up to my abuse Though they are difficult to make adjustments without them popping off (use two 2mm hex drivers to hold them in place).
#3371
Lunsford uses 6Al/4V grade 5 titanium which is the same grade as what I got and what most titanium for this application is...yup same stuff.
I know I've read on here where other people bought Chinese titanium round stock, and found that it bent easily.
YMMV.
#3372
I bought Lunsford turnbuckles individually in the same length as Tekno, but if I had to do it again I’d get some that are a couple of mm shorter. Stock turnbuckles are threaded almost all the way to the center, but my Lunsfords have a few mm unthreaded towards the center. With B5M ballcups, there’s not enough threads for some of the shorter camber link setups. 2mm shorter should work better.
