Tekno RC EB410 Thread
#2011
having put together quite a few diffs in a variety of vehicles, I thought that too while i tried to line it up and get it to go.
The fact of the matter is something that may be silly to you may help someone else get things built together easier to go and drive if a better way is out there. Example, the threading of the shock caps for one or when we came up with how to put the rear linkage on the shock tower on the first SCT410 by reversing the nut direction making it easier to get to
Also noticed that in the manual it mentions drilling out the bleeder hole with a 1/16th drill bit. This is not needed IMO and I don't think that the bleeder screw will work if you did so either. I skipped this step when I noticed this.
#2012
#2013
I kept telling myself I wasn't going to stock up on spares for this buggy because it's new and parts will obviously be made for a very long time. But my paranoia from dealing with my DEX210 has resulted in a giant pile of parts I just received from Amain lol. Even some spare Lunsford turnbuckles . I should be broke by Christmas
#2014
#2016
While not everything is 100% applicable to the small car, the diffs build essentially the same as the large vehicles, so here's my diff build video tutorial from the ET48. The drop through and sight methods both work well, though I always point the pins at the screws so it is always easy to not guess on things. Slightly longer of a video, but it explains pretty much everything (including a couple things you don't need to worry about here). Never had a leaking diff or diff construction issue since I stopped running the original Losi SCTE. LOL
+ YouTube Video | |
#2017
Recieved my Tekno a couple of weeks ago.
The build was good and the manual one of the best on the market in my oppinion.
The only complaint about the quality on the kit is the shock caps. I preffer aluminium as I change oil very frequent on my cars.
Overall a great kit. Run HW XR10 Pro and HW V10 5.5 motor in mine with great result. Have also had issues with turnbuckles, 2 of them have been replaced after broken in half..
Run all CF parts on mine now with different springs and front and rear swaybar kits.
Will go for Lunsford turnbuckles and waiting for alu caps to be released for the Tekno EB410.
#2018
Finally got my kit yesterday and dying to build it! My 3rd Tekno aside from my SCT410 and EB48SL.
#2019
So another guy at the with an EB410 came up to me and showed me that he had rubbing on the rear axles where the spring cups are from the rear shocks. It appears that with stock setup there is some very tight to no clearance causing the spring cups to ever so slightly rub the rear axles. Now this is not a big deal, just thought I would mention it. I never saw it on mine as I have my rear arms all the way forward...I also put a washer behind the shock eyelet to get about 1mm clearance just to be sure.
#2020
I noticed that. I put a 1mm shim between the arm and the shock eyelet. One run before that and the anodizing on the shafts was rubbed off because the spring cup.
Also, I noticed that the springs can go over the bottom cups. After I finished the race Saturday, I went to work on my shocks and a front spring went pass the bottom cup. The lip that holds the spring is really thin.
#2022
I know some of this has been discussed on the Facebook site (not by me), I thought I would share some observations on compatibility (fit only) with AE B64 and XB4 parts.
Center differential:
XB4 NOT compatible. Internal (plastic) gears NOT compatible.
B64D compatible when used with carbon center brace 6635C. Shims are needed to reduce slop. Internal gears not compatible. Stock weight with 81t spur is 43g vs stock EB410 is 34g. I don't have plastic B64 gears to check the weight.
Center slipper:
XB4 NOT compatible. Bearing spacing too wide and outdrives too long.
B64 slipper (92089) is compatible with carbon center brace 6635C and AE 110mm front dogbone (92065). The 78t spur (9652) works with this setup. Shims (at least 8) are used to reduce slop between bearings. Rubber spacers in outdrives recomended. Net weight of B64 slipper, 78t spur and 110 dogbone is 42g (33g slipper + 9g dogbone) vs 40g (34g diff + 6g dogbone) for EB410 front dogbone and gear diff. If going this route you may want to buy Shelle SHL1307. This comes with the AE 110 dogbone and 78t spur. I have not tested this but don't see why it wouldn't work.
I am in the process of converting my EB410 to a carpet setup. My plan is to start with the stock gear diff with 15K (will be running 13.5). Depending on how that feels, either go higher on diff oil or go to the AE slipper. There was a user on Facebook that tried the exotek eliminator (for B64) and found he liked the gear diff with 30K better.
Center slipper:
#2023
I had the spring come off also, I just took out the long setscrew that goes through the cup and shock end and that solved the issue. Maybe I'm missing something but not really sure why this long set screw is needed, I've never had a cup come off...there's already a lot of engagement
