Team Associated RC10B64 Thread >
Like Tree682Likes
    Hide Wikipost
Old 08-01-2017, 03:20 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Team Associated RC10B64 Thread
Last edit by: RCBuddha
Welcome to the B64 Wiki!
Quick links to all the sections on the first page!
Petit RC Page
B64D Manual
Aftermarket Upgrades
Petit RC Page
B64D Manual
Aftermarket parts
Helpful Tips and Videos
How to properly Shim the B64 Diffs
B64 Club Racer video
Print Wikipost
Old 09-08-2019, 03:21 PM
  #4216
I was looking at picking up the longer kashima shocks and possibly trying to use the b74 29mm shock shaft instead of the 27.5 but it looks like with any more droop in the rear than i currently have the cv axle will pop out. Has anyone tried this?
Jcnadeau13 is offline
Old 09-08-2019, 04:22 PM
  #4217
Yes. Used them for a bit when the longer shock shaft came out. The 67mm dogbones will allow you to run more droop.
trf211 is offline
Old 09-08-2019, 05:14 PM
  #4218
Did you like it or go back to the original length?
Old 09-08-2019, 06:16 PM
  #4219
Which shocks I used was kind of determined by what shocktower was available. I preferred the shocktowers with the inbetween camber positions with the additional 4th lower hole. Not many shock towers are available in the tall option with the camber position I liked. So I either ran the short shocks with the inbetween camber position and preferred the way it handled in the corners, or tall shock tower with better bump handling but a little slower cornering. If you can find a tall shocktower with the 4 middle camber positions, that's what I would recommend. The Bezerk HRC tall tower was pretty close and what I used primarily with the tall shocks.
trf211 is offline
Old 09-09-2019, 03:56 PM
  #4220
Unfortunately i cant order my motor esc combo yet but ive been itching to drive this thing. Would it be ok to run a sct motor temporarily? Specifically a fuze dynamite 3900kv 4 pole.
Old 09-12-2019, 09:28 PM
  #4221
Does anyone know if the B74 front 8* caster blocks would fit on the 64? It looks like they would, just trying to confirm before buying them.
Thanks!
ten2doyle102 is offline
Old 09-15-2019, 08:09 PM
  #4222
Can anyone recommend a good setup sheet to start from. I know some of the pros have a very aggressive setup. I am looking for something fairly stable and easy to drive. My track is a small technical indoor track with clay that varys from high grip when wet but gets dusty quickly.
The only upgrade I have is the v2 steering rack im waiting on the rest of the recommended parts to arrive.
Old 09-15-2019, 11:48 PM
  #4223
I find Dustin Evans setups easier to drive while rivkin's are generally more aggressive. I'd look for an Evans setup to start with.
Di_spencer is offline
