Team Associated RC10B64 Thread >
Like Tree648Likes
    Hide Wikipost
Old 08-01-2017, 03:20 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Team Associated RC10B64 Thread
Last edit by: RCBuddha
Welcome to the B64 Wiki!
Quick links to all the sections on the first page!
Petit RC Page
B64D Manual
Aftermarket Upgrades
Petit RC Page
B64D Manual
Aftermarket parts
Helpful Tips and Videos
How to properly Shim the B64 Diffs
B64 Club Racer video
Print Wikipost
Old 02-08-2019, 12:58 PM
  #4051
BmainStar's Avatar
Default New Car
Had to get out of the Hobby for a bit.My 64d was very dialed and very stout.Hardly many breaks or failures.I would clean it ,put it away ,pull it out and Run.Very Excited to see a New Car hope
a D version still exists.
Cheers Racers
Happy New Year
Happy New Car
BmainStar is offline
Old 02-09-2019, 10:43 AM
  #4052
RazorRC's Avatar
B64 is down to $329 at amain...
RazorRC is offline
Old 02-10-2019, 06:11 PM
  #4053
Anyone know where to get both the front and rear -2 towers? Found rears on amain and fronts from vision racing but cant find a set from the same place.
Sodakota is offline
Old 02-11-2019, 06:24 PM
  #4054
Wildcat1971's Avatar
Trader Rating: 83 (100%+)
johnny 5 designs
https://j5designs.net/search?q=b64
Wildcat1971 is offline
Old 02-12-2019, 08:41 AM
  #4055
I am looking to do the rear camber link mod to move them in front of the tower on my B64D and have a few questions to clarify after reading through the many posts throughout this thread:
I assume I don't have to run the 2mm shorter arms with this if it's not needed? If not where should i run my hub spacers?
I have seen multiple spacer lengths on top and bottom of shocks so are the different lengths being used as a tuning option? Of so what should i start with on top/bottom?
I saw somewhere it's better to use the optional aluminum rear hubs for this mod? Is it still a benefit if I'm using the stock hubs?
Bluenose76 is offline
Old 02-12-2019, 03:22 PM
  #4056
socalcloin's Avatar
I did the setup with the stock rear arms and stock hubs. It works fine.
The spacing on the top and bottom of the shock away from the shock tower is to make room for the camber link and to get your shock movement lined up with your arm movement. If you have extra anti-squat (the front of your rear arms is higher than the rear) you will want less spacers on top. Basically the angle the arms go up and down should be the same angle as the shock, or it can bind a little. If you are using the stock arms, then the shock does not need to be spaced as far forward. Also I think the pro setups they are also just trying to shift more weight forward so they have even longer stand offs.
socalcloin is offline
Old 02-12-2019, 03:25 PM
  #4057
ok cool! What dis you end up with on top/bottom spacing?
Old 02-12-2019, 04:03 PM
  #4058
socalcloin's Avatar
A couple washers from my RCscrewz kit on top and a single 1mm spacer on bottom was correct for my pill settings. The washers are close to 1mm so about 2mm on top. I am using the stock shock mounting hardware so I could not space it out any further really. Otherwise you need to get longer bolts or 3rd party stand offs.
Edit - correction it is 3 washers on top
Old 02-12-2019, 04:20 PM
  #4059
awesome thanks!
Old Yesterday, 03:29 PM
  #4060
Default Aluminum Rear Hubs
I am looking to upgrade to aluminum rear hubs and even though both the AE and Schelle hubs are out of stock everywhere it seems, I am looking for opinions in which to grab once they come back in stock or I find a used set somewhere in the meantime
Old Yesterday, 05:06 PM
  #4061
Amain has the AE and exotek alu hubs if you can't find them locally.
trf211 is offline
Old Yesterday, 05:18 PM
  #4062
I will have to check again...last time i looked everything was out of stock
