Team Associated RC10B64 Thread >
Like Tree673Likes
    Hide Wikipost
Old 08-01-2017, 03:20 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Team Associated RC10B64 Thread
Last edit by: RCBuddha
Welcome to the B64 Wiki!
Quick links to all the sections on the first page!
Petit RC Page
B64D Manual
Aftermarket Upgrades
Petit RC Page
B64D Manual
Aftermarket parts
Helpful Tips and Videos
How to properly Shim the B64 Diffs
B64 Club Racer video
Print Wikipost
Old 03-12-2017, 07:47 AM
  #1546
Davidka's Avatar
Trader Rating: 81 (100%+)
Originally Posted by sgtlt View Post
If you are not talking about the B64 why are you on here. Go bitch at each other somewhere else, please.
You're right, shouldn't have bothered with that.
Carry on..
Davidka is offline
Old 03-12-2017, 08:21 AM
  #1547
Originally Posted by RC*PHREAK View Post
first thing i'd do is put red springs up front. my buggy was doing a lot of what you're describing when i had white springs on the back. red springs made a huge difference. i also have 32.5 in the rear shocks and 10/200/7 for diffs and it feels great.
OK red front and stay with white in rear?
Trickyii is offline
Old 03-12-2017, 09:20 AM
  #1548
Kalio's Avatar
Originally Posted by Trickyii View Post
First day of running at the track. Running the Alex kosciuszek set up sheet.
Way too twitchy. Feels like the car is floating back and forth and I can't get it to settle down. When I turn there is that moment of oversteering then the correction and then counter correction. Fought that all day. Felt like oversteer?
What should I be looking to do to help correct this? 37.5wt yellow front shocks, 5k front diff. 30wt white rear shocks 3k rear diff. Car was wanting to go left/right swaying back and forth. 20mm ride height.
I always had this problem with my B44.3... was hoping this new B64D would be easier to drive, which I'm about to start building. Hopefully some of the suggestions others have offered will help.
Kalio is offline
Old 03-12-2017, 09:31 AM
  #1549
Kalio's Avatar
It seems like guys are running much thicker center diff oil (200k +) in this B64 compared to the B44 (mine usually had 60-100k). Can anyone explain why? I'm going to be building this car to run outdoor in low to medium grip dirt and used to put in 60k, not sure what to use now.
Kalio is offline
Old 03-12-2017, 09:37 AM
  #1550
My first B64 experience couldn't of been more different than that guys. Maybe that setup he used is shit for his track? My car using the kit set was super easy to drive, it tracks super straight, jumps good. Definitely better than the 22-4 2.0 I had been racing.
mgers75 is offline
Old 03-12-2017, 11:07 AM
  #1551
RC*PHREAK's Avatar
Trader Rating: 128 (100%+)
Yes
RC*PHREAK is offline
Old 03-12-2017, 11:27 AM
  #1552
Krio's Avatar
Trader Rating: 152 (99%+)
Diff cases are more open/bigger and the gears are a tad larger, reducing the oils ability to resist motion. Thicker oil is required to get the same diff action as before.
tom73 and sgtlt like this.
Krio is offline
Old 03-12-2017, 11:50 AM
  #1553
I agree. The set up I used was not the stock but was offered on AE site. It obviously didn't work for my track or my driving style.
The real take away here is that others have seen the same reaction out of the car as I described. All it means is that a better setup is out there for me. Last year,my b6 was good out of the box but lacked rear traction. I'm not afraid of spending time finding the best setup for me. Just asking for thoughts and tips.
I'm going to start with thickening up the front and rear diff oils, going up to 32.5 in the rear shocks and then play with different springs.
Trickyii is offline
Old 03-12-2017, 12:12 PM
  #1554
My local hobby shop loves the Spektrum 6240. Tried to use one with my B5M, wouldn't fit with the removable plug. Bought one to try with the B64d.
The cable is kinda ackward in this chassis too. Think this bend is going to be a problem?
intercede007 is offline
Old 03-12-2017, 12:26 PM
  #1555
Krio's Avatar
Originally Posted by 5tone View Post
Hi mates !
just starting my build; and the top plate (92038) is not perfectly aligned with the steering posts (about 1-2 mm )
i had to force on the chassis to assemble those 2 parts
is it normal ?
i also have the right bellcrank slightly rubs the right siderail... on max angle
note that the left side doesn't rubs.
I had this same issue and it isn't normal, but it doesn't seem to be a common problem either.
AE is out of chassis at the moment, so they will be sending me one as soon as they are in. If I tried to assemble it as-is, I had to put a good 10 lb of force on the shock tower to flex the nose back enough for the holes to line up. In the meantime, I opened up the holes in the upper deck to remove some of the tension in the front assembly and it survived it's first raceday.
Take some quality pictures and email them. They should take care of you.
Krio is offline
  #1556
Trader Rating: 29 (100%+)
The bend will be fine. The outer rubber/casing looks like there is "stress" but the wire inside will be ok.
intercede007 likes this.
DustinEich is offline
Old 03-12-2017, 12:59 PM
  #1557
You can cut off that outer rubber gromet next to the servo. You can also get servo wires that don't have the outer cover from Horizon. Different lengths also.
intercede007 and jpcopeland1 like this.
sgtlt is offline
Old 03-12-2017, 01:43 PM
  #1558
Used AE Stigs turf recommendations today and the car was planted. Had an awesome practice. 1st race will be next week.
Tobey457 is offline
Old 03-12-2017, 02:43 PM
  #1559
Trader Rating: 508 (100%+)
I made a couple of changes today that made the car worlds better. Its competitive now. I changed the rear springs to white and moved the ball studs on the front tower in the #2 position (making the camber links longer. It calmed the car down a lot. Now I just need to get some laps in. FYI, I also regeared my Reedy Mach 3 13.5 from 81/28 to 78/28 and I'm going back. Ran like poop. Going back to the 81 spur..
QDRHRSE is offline
Old 03-12-2017, 07:13 PM
  #1560
Trader Rating: 40 (100%+)
I tried it too, had to use a front sway bar in the rear. Rear end was still a little loose but I think I'll have it dialed in by our next points race in 2 weeks
Scott R is offline
