Team Associated RC10B64 Thread >
Like Tree673Likes
    Hide Wikipost
Old 08-01-2017, 03:20 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Team Associated RC10B64 Thread
Last edit by: RCBuddha
Welcome to the B64 Wiki!
Quick links to all the sections on the first page!
Petit RC Page
B64D Manual
Aftermarket Upgrades
Petit RC Page
B64D Manual
Aftermarket parts
Helpful Tips and Videos
How to properly Shim the B64 Diffs
B64 Club Racer video
Print Wikipost
Old 03-10-2017, 09:20 PM
  #1516
Trader Rating: 508 (100%+)
I guess I'm a little underwhelmed too. The car is so f'n twitchy its hard to drive. Its a good car though. I was able to turn a couple hot laps but I couldn't run a lot of them. It lands great. It lacks the stability of the 22-4 2.0 for sure. Its very edgy and needs to be pushed very hard. I toed the front wheels in 1 degree and that helped a lot. I'm going to run it for a couple of weeks and give it a proper chance. My first [honest] impression is that I like my TLR wheelers better. I'm not aggressive enough to get the B64D to work right but I'm going to stick it out a while longer.
QDRHRSE is offline
Old 03-10-2017, 10:19 PM
  #1517
Originally Posted by Cain View Post
in general, what do you guys feel is one of the better fans to use for cooling a 1/10 4wd buggy motor (high cooling speed, durability). I have seen a few at the track, some just seem to make a bit more noise than others.
The WTF Windy fan should cover everything you need it to do.
John Myall is offline
Old 03-10-2017, 10:21 PM
  #1518
Did you run it box stock setup? I was surprised that the front rollbar was so much thinner than the rear, but change that and springs & it should settle down nicely.
Mine was really good on a flooded astro track last week, before the water found the speedo
Old 03-10-2017, 11:15 PM
  #1519
Deleted - I get why turning the center diff should be like stirring a pot of hardening 30 minute epoxy now
intercede007 is offline
Old 03-11-2017, 12:34 AM
  #1520
5tone's Avatar
Default top plate not aligned
Hi mates !
just starting my build; and the top plate (92038) is not perfectly aligned with the steering posts (about 1-2 mm )
i had to force on the chassis to assemble those 2 parts
is it normal ?
i also have the right bellcrank slightly rubs the right siderail... on max angle
note that the left side doesn't rubs.
5tone is offline
Old 03-11-2017, 04:33 AM
  #1521
Got to spend some more time with the buggy last night, was nice as I raced through the build. Some observations.
- I think people are cracking the transmission cases for a couple reasons. A) pre-thread the case with an extra screw and black grease. Run the screw into each hole a couple times. This loosens up the threads / hole and gets the excess plastic out of the hole. And B) some of the screws are too long (for example those for the wing mount and rear shock tower. If you wind those 14mm screws in tight they will push out or crack the opposite side.
- the front sway bars will fit the rear, not sure if they will work but there seems to be clearance. The angle of the bend might not be optimal for the rear though as the end links are skewed.
- the center diff needs to be shimmed too, it's loose and could hit the top cover. Think I used 4 shims to push the assembly forward.
- my rear diff was binding in one spot, shimming and wrestling with it got me nowhere. AE sent me a new gearbox case and it fixed the issue.
That's all I got!
Tobey457 is offline
Old 03-11-2017, 09:30 AM
  #1522
Buzz209's Avatar
Purchased the Maclan 30mm HV Turbo Fan and ran it all last season without issue. Kept the motor cool during the summer months when ambient temps are regularly above 100 degrees.
Amain sells the fans for $12.99, item #MCL4016.
Buzz209 is offline
Old 03-11-2017, 11:19 AM
  #1523
There is no way that the updated turnbuckle measurements are correct. I had atleast 5* or more of toe in at the front and nearly 10* of camber. I ended up going 2mm longer on the camber and 2mm~ shorter on the steering turnbuckles to get it right.
At the default settings when turning to full lock at either side it would cause the opposite arm to rise up, even before putting on the swaybars and shocks.
Other than that my build went together pretty well. I haven't had it out at the track yet but here in the yard and on the street it has a ton of steering. My only complaint is how little space there is under the body shell, it makes running electronics a PITA.
jimmer411 is offline
Old 03-11-2017, 01:13 PM
  #1524
TAW
Trader Rating: 18 (100%+)
Did you actually use calipers to measure when you built them? The drawings are not to scale. I have now built two 64's by the supliment measuresments and they have been pretty spot on.
TAW is offline
Old 03-11-2017, 04:55 PM
  #1525
First day of running at the track. Running the Alex kosciuszek set up sheet.
Way too twitchy. Feels like the car is floating back and forth and I can't get it to settle down. When I turn there is that moment of oversteering then the correction and then counter correction. Fought that all day. Felt like oversteer?
What should I be looking to do to help correct this? 37.5wt yellow front shocks, 5k front diff. 30wt white rear shocks 3k rear diff. Car was wanting to go left/right swaying back and forth. 20mm ride height.
Trickyii is offline
Old 03-11-2017, 05:06 PM
  #1526
Thrifty's Avatar
Hope these issues are sorted out by the time the "carpet" version is released.. might pick one up then..
Thrifty is offline
Old 03-11-2017, 05:23 PM
  #1527
I would think thicker diffs front and rear. Why are they so low?
roffutt is offline
Old 03-11-2017, 05:33 PM
  #1528
storm800's Avatar
Trader Rating: 23 (100%+)
10k-200k-10k have been good on Coles car so far. We haven't run with the 10 degree castor blocks much, but with the 13 degree his car has been money. Not running the gearbox shim either.
storm800 is offline
Old 03-11-2017, 05:41 PM
  #1529
Trader Rating: 20 (100%+)
MIP is running some prototype puck drive parts for the 13.5 class B64 at the desert classic. Front, rear, and center shafts. Supposedly a 20% decrease in rotating mass.
MX304 is offline
Old 03-11-2017, 05:44 PM
  #1530
Following this setup sheet as this is my home track https://www.teamassociated.com/pdf/c...ans_Rumble.pdf
I'm on page 10, Steering Block Build, step one. Is the axle height setting in the setup sheet the caster block bushings? Instructions want the thick bushing to the bottom, but it seems like my setup sheet would put the thin bushing on the bottom. Is that how the axle height setting is made?
