TLR 22 SCT 3.0
#751
just got an add that says the new truck will be out Feb COOL.. and as for gearing. your looking good.. motor should be in the 160's same with esc. smaller pinion tell they all run safe . motor turns 30.000 try to get it so it still pulling at the end of the longest straight..and still running cool
#752
I own 2 of these, but they are the rear motor older version. I'm glad TLR made it to a mid-motor. I plan on updating and getting a couple of these Newer ones
#753
Forgive me, this us going to be long. I bought a 22sct 3.0 from the owner of our local track. I put my electronics in it but I used his hobbywing just stock ESC and my v4 schuur speed 13.5t motor. He previously had a trinity monster max 13.5 so when I geared it, I matched his gearing. I think the spur is a 76 and the pinion was a 25. I did a full race and motor was 325 degrees F. Yes you read that correctly. Luckily, it somehow still seemed to work fine. So I dropped the pinion tooth to a 21t. After two minutes on the track, it was at 200 degrees F. I have no idea what to do gearing wise. I've been told to make sure no bearings or drivetrain parts are locked up or spinning rough causing extra work. I haven't done that yet but will try to soon. I sure could use some help on ideas/theories and gearing suggestions. Thanks in advance
#754
Will the new SHDS slipper from 5.0 buggy fit into the SCT?
#755
I have the laydown transmission in mine and installed the SHDS slipper.. I needed to use 5.0 layshaft. I'm fairly certain it will still also work if you have the original stand up transmission as long at the layshaft has the same number of teeth in it.
#758
I'd go with the 4.0 parts option. The lower tower/shocks will improve the CG for SCT for sure. And, you'll be able to work off team driver setups, since these are the parts they'll be running. I believe the Exotek version has a different diff height, so I'm not sure how that will compare to our specifically engineering diff height (that the rest of the suspension geometry is based on). Also, if you go the 4.0 route, you'll be able to buy all of the spare parts, and the larger idler is more durable as well as being able to mount shocks in front.
Parts needed to convert an SCT 3.0 to laydown:
TLR234093
TLR234092
TLR233024
TLR233014
TLR232068
TLR231066
TLR232069
TLR232067
EXO1752
TLR234093
TLR234092
TLR233024
TLR233014
TLR232068
TLR231066
TLR232069
TLR232067
EXO1752
#760
Pardon the somewhat-long post, but I am providing info, as well as inquiring info. For those interested in doing the laydown conversion, I came across a video on YouTube, by Vertical Extent RC, and there is a downloadable template, which not only shows where to drill the holes, but also includes a parts list, as well as step-by-step instructions. I did, however, notice some discrepancies in the two parts lists (ie. Frank's, and Vertical Extent's). Here are the two lists, side-by-side:
EXO1752 EXO1752 Aluminum Body Mount Set
TLR232067 TLR232067 3-Gear Laydown Gear Case Set
TLR232068 TLR232068 3-Gear Laydown Motor Plate
TLR231066 TLR231066 Laydown Chassis Brace
TLR234093 TLR234093 Laydown Rear Shock Tower
TLR 234092 TLR332070
TLR233024 TLR233002
TLR233014
TLR232069
As can be seen, the first five parts are the same, but the remaining parts differ. With Frank's list, there is the rear arm set (TLR234092), the 55mm shock shafts (TLR 233024), the shock bodies (TLR 233014), and the Laydown Idler Gear & Shaft (TLR232069). With the list from Vertical Extent, the different parts consist of the Aluminum Laydown Idler Gear & Shaft (TLR332070), and the 50mm shock shafts. It appears that, instead of replacing the rear shock bodies & shafts, Vertical Extent has chosen to stick with the stock shock bodies, and only replace the shock shafts, but with shorter shafts that those included on Frank's list. Additionally, Vertical Extent has opted to go with the aluminum idler gear, as opposed to the plastic idler gear listed in Frank's list. Before I continue, is a clay track environment, is there any advantages/disadvantages in the plastic vs aluminum idler gear? The only other difference I notice is that Vertical Extent has elected to stick with the stock rear arms, while Frank's list includes the Stiffezel rear arms. Again, in relation to racing on a merdium-to-high grip indoor clay track, what are the advantages/disadvantages of using the stock rear arms vs the Stiffezel rear arms?
I'd prefer to not order parts bit-by-bit...if I'm going to go the 22SCT route, with laydown conversion, I'd rather get all my parts ordered together (my AMain cart has everything listed above, plus the 22SCT 3.0 & electronics), so I'm just waiting for 'assistance' before I delete the "unnecessary" parts, and place the order. Thoughts?
TLR233024 TLR233002
TLR233014
TLR232069
#761
TLR233024 TLR233002
TLR233014
TLR232069
TLR233024 TLR233002
TLR233014
TLR232069
Regarding the arms, the stifzel arms should already have the holes in the front if you want to mount the shocks on the front. But if you stick with your stock arms you can always just drill the holes to mount the shocks forward.
#762
I would run the aluminum idler, SCTs are tough on idler gears.
Anybody running the brass weight parts in stock form on indoor clay?..
Anybody trying to run 5.0 steering parts on their SCT with either the stock stand up rear or 4.0 lay down conversion?
#763
Yes 5.0 steering rack and laydown much better on the truck.
#764
Here is some running video of the truck. is is super amazing to drive. Has to be the best handing SCT I have ever driven.
https://tinyurl.com/yy5chesc
More post to come on the RCLYFE 22SCT
Give us a link if you like what you see.
#765
Thanks for the replies. Appears I need to drop some money in the 3.0..lol
