Old 01-05-2006, 09:12 PM   #1
Default Changing my Piston and Sleeve
I just bought a new piston and sleeve, so it's time to take the old one out and the new one in... But one BIG problem, I don't know how.
Is there a good step by step article showing me how to do this? Or can anyone describe in very good detail on how to do this?
Pictures say 1000 words.
Thanks.
Fewski is offline   Reply With Quote
Old 01-06-2006, 01:58 AM   #2
Team Duratrax's Avatar
Send a message via MSN to Team Duratrax
To put it simple.
Unscrew the head and unscrew the backplate to have access to the conrod. Take out the sleeve by simply pulling on the lip with a pair of needle-nosed pliers. The sleeve will slide out very easily. Now, go back to the backplate and pull on the conrod so that it slides off from the cam. The conrod/piston will then be dangling around inside the crankcase and you will then be able to take it out.
I'll let HPI cover installing the new piston/sleeve:
http://www.hpiracing.com/index2.htm
Team Duratrax is offline   Reply With Quote
Old 01-07-2006, 12:46 PM   #3
Thanks for the link!
But, I can't seem to get the connecting rod off the old piston. There was a little spring like thing on one of the sides, I took that out.
How do you get the connecting rod off the piston? I see the little bar the connecting rod is connected to, but can't get it off.
Old 01-07-2006, 01:06 PM   #4
JusBox's Avatar
You might have to force the wrist pin out. That's the little bar you're talking about. Be careful not to damage anything.
JusBox is offline   Reply With Quote
Old 01-07-2006, 01:14 PM   #5
Thanks for the reply. Should I put the old piston in a vice and take an ice pick and a hammer and litely tap it?
Old 01-18-2006, 11:24 AM   #6
layedbackguy's Avatar
Trader Rating: 15 (100%+)
Send a message via Yahoo to layedbackguy
Nooooooooooooooooooooooooooooooooooo!!! The easiest way to change your piston and sleeve, is to use take the head, and back plate off. Remember to place your head shims somewhere where you can find them when puttting the head back on....Insert a thick zip tie into the exhust port and turn the crank, leave the fly wheel on makes it way to turn..dont forget to take the con. rod of the crank. Once you turn the flywheel, the sleeve will push to the top. I wouldnt use pliers or any tools to remove it or reinstall the new one. It should go back in very easy, just make sure you put it back in the same way the old one came out.
layedbackguy is offline   Reply With Quote
WTB MT-12 PISTON, SLEEVE, CON. ROD BIG DADDY8 R/C Items: Wanted to Buy 1 05-24-2006 03:11 AM
wtb: xtm 24.7 pro piston and sleeve lp1066 R/C Items: Wanted to Buy 1 03-13-2006 12:13 PM
RB Ws7 2 piston and sleeve layedbackguy R/C Items: Wanted to Buy 0 05-19-2005 11:45 AM
RB WS7 2 piston/sleeve layedbackguy R/C Items: For Sale/Trade 0 05-19-2005 11:38 AM
ABC sleeve and piston??? JInaba Nitro On-Road 2 12-13-2004 12:26 AM
