Old 12-30-2005, 06:31 AM   #1
Post head shims
is there a formula or anything to tell you how many shims and the thickness of them to use by the amount of nitro in your fuel? i bought a werks racing /picco .27 that the factory said was shimmed for 30%. and i belive the deck height was.030 if that is true can i safely remove the .010 shim for a total of .020 clearance and run it with 20%. can some one please help me.
harddrive is offline   Reply With Quote
Old 12-30-2005, 11:55 AM   #2
SlobbaTech's Avatar
If you got .030" gap between piston/button by using solder method then it's right and good for 30%. If you measured the shims individually and added them up and also measured button + piston from top of sleeve "method" then this way isn't as accurate and had a lot greater window of human error. If you want to go to 20% then you can remove a .1mm/.004" shim to take deck height down to .026" safely but try to not go below .023".
Hot Bodies, HPI, Novak Electronics, JR Propo, Lunsford, Skipgear.com, Planet R/C, Vinyl Graphics Unlimited, JConcepts, B-Mods Racing, CRCRC, King's R/C Raceway, Avid R/C, GMK Supply, & Pacific Coast Hobbies.
SlobbaTech is offline   Reply With Quote
Old 12-30-2005, 12:17 PM   #3
Default headshims
i measured the shims individually with a mike- one being 0.10 and the other being 0.22. using 20% fuel can i safely remove the 0.10 shim and just use the one- 0.22?
Old 12-30-2005, 03:47 PM   #4
Trader Rating: 14 (100%+)
Be on the safe side and go spend 1 dollar on some shims. You will find one that is thinner than .10, once you do, put that in along with the .22 and you will be ok.
o.s. power is offline   Reply With Quote
Old 12-30-2005, 07:32 PM   #5
Default head shims
ok thanks guys.
Old 12-30-2005, 09:43 PM   #6
SlobbaTech's Avatar
You really should measure your deck height by having engine together...no glow plug...take piece of solder and bend into "L" shape and stick it into engine glow plug hole...turn engine over once by hand while holding solder to sleeve wall/side of engine...then measure the solder afetr it's compressed to get your actual deck height. A .1mm shim = .003-.004" and is the thinnest they come.
Head shims for a VZB jrwoodchuck Nitro Off-Road 12 02-16-2008 04:30 AM
Head shims to run 30% in a RB S5 motor. Mpowerz Nitro Off-Road 22 01-12-2008 06:49 PM
OS VZ-B head shims porter Onroad Nitro Engine Zone 0 08-01-2006 08:17 PM
Rb C4 head shims rrgt_kid Onroad Nitro Engine Zone 1 03-06-2004 02:59 AM
head shims and 30% question nitroaddict Nitro On-Road 4 11-12-2003 08:44 PM
