Old 12-29-2005, 05:52 PM   #1
D Hunt 3's Avatar
Send a message via MSN to D Hunt 3
Default What Pinion????
I have a Duratrax Evader ST pro and I need to find out what pinion to use. All I can tell you is the internal drive is 2.66:1 and the spur gear is 86t (48 pitch). Any help will be appreciated!
D Hunt 3 is offline   Reply With Quote
Old 12-29-2005, 07:14 PM   #2
Trader Rating: 28 (100%+)
Need to know what motor you run also.
jbrow1 is offline   Reply With Quote
Old 12-29-2005, 08:08 PM   #3
D Hunt 3's Avatar
right now i'm just running in the stock class. It's an epic outlaw pro 2 if you need to the specifics.
Old 12-29-2005, 08:12 PM   #4
I've never ran an evader, but I'd probably try a 19 tooth in there and then adjust from there after you drive it and see how it feels.
Old 12-29-2005, 08:38 PM   #5
D Hunt 3's Avatar
Ok-thanks for the help!!
Old 12-29-2005, 08:49 PM   #6
No problem. It's nice to have a range of pinions to try. Say like 18-21 for starters. Gearing all depends on what motor you have. To high a # and you can overheat your motor which can burn up your comm and your brushes.
Old 12-29-2005, 08:55 PM   #7
Suspended
if your racing then dont go that high that motor will be toast asap. a guy i raced with always ran 17/87 with a p2k. that motor really isnt a truck motor. too rpm-ish. get a p2k or p2k2 for it and you will be happy
THE_REAL_FROBOY is offline   Reply With Quote
Lot of 14 Pinion Gears, 2 Pinion Holders, and 3 Spur Gears (64 Pitch) MyRCTrader R/C Items: For Sale/Trade 4 02-04-2008 07:08 AM
WTB: Pinion set 48P corman007 R/C Items: Wanted to Buy 1 10-14-2007 11:47 PM
Would switching from a 19t pinion gear to a 21t pinion make a big difference ? thahookup Rookie Zone 5 05-19-2006 01:09 PM
pinion for a t4 papadocks Electric Off-Road 2 07-18-2005 11:59 PM
Big Pinion / Small Spur - OR- Small Pinion / Big Spur -- Difference? rctoyguy Electric On-Road 7 07-12-2004 05:54 PM
