XX-4 Forum
#46
Damn now I'm even more confused
Stupid noob.
Ok, what's a spool? What's a clicker? I'm assuming the clicker is the thing that goes click when I push the car right? I'm also assuming that that clicker is so when the front end of the car lands before the rear that the front spins without spinning the belt and affecting the rear of the car? Is that correct?
Stupid noob.
#47
Not a stupid noob. Eveyone has to learn. Hell, I'm learning a lot about off road lately. I'm an onroad guy with no local track. Gotta race something between trips to LA to race. 4wd buggy is the closest to running an onroad car
Spool= solid/locked front diff. Used a lot in on road. Provides massive amounts of steering exiting corners but you loose a lot of turn in since the front tires aren't allowed to turn independently of each other.
Clicker= The center clicker oneway that allows the front diff to spin independently from the rest of the drivetrain. It allows for the front to spin faster than the rear when needed and gives more steering. A regular oneway like what's used in on road and what the XXX4 uses allows each front wheel to spin totally independently from the drive train and each other forward but locks under acceleration. Worst part about any kind of oneway is you loose front wheel braking. Any 4wd car without oneway in it will stop on a dime as long as the tires can grip. Put the oneway in it and you loose front wheel braking and the car will try and spin out if you're braking too much. It makes the car very unstable under braking. More so than a 2wd car under braking because of the added rotating mass of the larger, heavier front tires, axles, CVD's, outdrives, etc... trying to continue spinning while the rear tires are braking hard.
#49
Probably not man, I might go and watch, but I haven't even been on dirt yet, let alone a track. I got into this late October. Being that Winter starts around August in New England , I haven't had much time to run. This is indoor I assume?
Kevin
Kevin
#51
KNUCKLE...
YES IT IS A INDOOR TRACK..YOU SHOULD COME ON DOWN AND RACE. THEY HAVE A SPORTSMAN/NOVICE CLASS. EVERYONE HAS TO START SOME TIME AND NO TIME LIKE NOW..GET YOU READY FOR THE OUTDOOR IN THE SUMMER. THEY HAVE A LOT OF NEW PEOPLE THAT RUN THERE SO DON'T THINK YOU'LL BE ALONE...HOPE YOU MAKE IT..
#52
Originally Posted by ApexSpeed
Oh, and let me throw the first plea out there to Losi to pull out a short run Limited, Limited Edition Class 8 Ford truck body like they used to have for this chassis.
#55
I haven't tried it eithr but there are a couple of modifications you have to do to the bulkhead to get it to work. There are good instructions on http://www.4wdrc.com/tech.htm , plus pics of the front bulkhead modification.
#57
Originally Posted by OldSkool
Has anyone tryed a 1 way out of a XXX-S/XXX-4 in the XX-4WE?
And locked up the clicker?
I haven't read it any where thats all.
Unless I missed a page.
#58
#59
#60
Originally Posted by stulec52
Apex,
well it's in a shop, and priced at $50 + any shipping fees.
told you.....
told you.....
