Your favorite Tire Sauce recipe >
Like Tree58Likes
Old 06-28-2016, 07:41 PM
  #16
JsK
JsK's Avatar
Originally Posted by jonski View Post
Have you noticed any adverse effects from using the LW? I have used it and Sticky Kicks on our indoor track, but people were telling me that the LW would swell the tires. Traction was great with it.
Never noticed a problem, i have a set of dirt webs that have prob been sealed in a bag for 2 years because of the wheels there on and they where LW heavy. Dont punch holes in the tires though(make sure the rim is vented) since any sauce is gonna attack the foams.
JsK is offline
Old 06-29-2016, 05:19 PM
  #17
Trader Rating: 35 (100%+)
Originally Posted by JsK View Post
Interesting that m4s are the tire of choice, in my experience clay coumpounds definetly seemed to react better to sauce than m4 or ss. You might try gold dirtweb/smoothys or some mc primes. Dont be discouraged if they dont work right away sometimes they need to scrub in first, you can help that along with a 80grit sanding block.
Have never found a better suace for Jc golds than blue can LW, dirt cheap also.
I've got some MC Primes I'm planning on testing out this weekend. A used set came with a backup buggy I bought off here a few months ago.
But the "fast guys" at the track say that MC isnt as good as M4
xjwolfpacker is offline
Old 06-29-2016, 06:13 PM
  #18
rustyus's Avatar
Originally Posted by Slashn77 View Post
I thought the yellow top lubricant LR was always the LR to use. Never heard of anyone using the penetrating LR
The teal cap Liquid Wrench stuff was a mixture of lubricating & penetrating oils. It's not made anymore.
rustyus is offline
Old 08-10-2016, 12:03 PM
  #19
Trader Rating: 32 (97%+)
pretty good list of ingredients worth experimenting here:
http://www.rccaraction.com/blog/2015...ion-compounds/
Mineral Spirits, WD-40, Diesel Fuel, Simple Green, Kerosene, Denatured Alcohol, Distilled Turpentine, Oil of Winter Green, Food Grade Wax, ISO Alcohol, Windex, Lighter Fluid, ATF, Acetone, Rosin
it might be worth trying each ingredient separately and then provide a ranking of the effectiveness for each on a scale of 1-10, then you can mix different blends together until you find a combination that works well for you.
I've been using Liquid Wrench Blue (LWB) for a cost effective method by spraying the fluid into an empty Associated shock bottle, the tip of that bottle works perfectly as an applicator to minimize waste. When traction is down, I'll use Sticky Kicks Pink (SKP) which is more aggressive (also wears the tires a little quicker too). I can't help but notice that SKP evaporates very quickly and I can apply it moments before a race making it one of the better sauces I've used, though significantly more expensive than LWB, plus I also use LWB to spray my car down for a good general cleaning agent before blowing it off with an air compressor.
Seeing how RCPhreak recommends mixing Brake Cleaner with LWB, I would imagine that would help it dry quicker too... LWB by itself tends to take about 15-20 min to dry without a fan.
Perhaps the higher the ratio of Brake Cleaner, the faster the mix will dry?
I kinda wonder if I can recycle my nasty used acetone that I use to remove tires might double up as a substitute for brake cleaner to help the LWB dry quicker? After all, there is residual CA that is dissolved in the mixture... maybe that will help add traction too, ha!
billdelong is offline
Old 08-10-2016, 12:36 PM
  #20
seth556's Avatar
Trader Rating: 43 (100%+)
Diesel.
seth556 is offline
Old 08-10-2016, 12:37 PM
  #21
Why not just get LW in the 4oz bottle, no need to spray aerosol into another bottle. (Availability is probably a concern, have never seen the bottle in an auto parts store)
https://www.amazon.com/dp/B000ABCH6E...ter_B00SN5GGOI
WRXnItUp is offline
Old 08-10-2016, 12:53 PM
  #22
BRSracing's Avatar
Trader Rating: 66 (100%+)
Originally Posted by Socket View Post
This. Diesel can not be beat. Both for cancer causing through inhalation, and traction.
Real modified and sprint car racing learned the dangers of saucing tires years ago. The rc industry still has to go down the path before they get smart and ban it all like the real cars. Some real race tracks will ban drivers for life if they get caught soaking tires.
BRSracing is offline
Old 08-10-2016, 02:52 PM
  #23
2 parts kerosene to one part PB blaster. Works great and cheap!
maximuspowell is offline
Old 08-10-2016, 04:04 PM
  #24
Trader Rating: 28 (100%+)
Can you elaborate? I know nothing about those types of racing. I prefer a loam track with step pins, wish panther and losi still made studs
Big_Show likes this.
jbrow1 is offline
Old 08-10-2016, 08:26 PM
  #25
Stuff is BAD for you and the environment. And mixing it can cause some serious reactions.
Hauptmann6 is offline
Old 08-10-2016, 10:25 PM
  #26
WillS's Avatar
Trader Rating: 31 (100%+)
I use regular Cheatersauce and I take a few months to finish a bottle. I apply a light coat using a toothbrush typically 15 mins before running and its dry with a tacky feeling. Works great on slicks (knocks the edginess off), no swelling/ballooning of the tires, doesn't wear off half way through the run and has little to no smell to it. Amain carries the stuff so its easy to get.
WillS is offline
Old 03-04-2017, 09:09 AM
  #27
JAE
Trader Rating: 30 (100%+)
Someone at my track had some sort of blend of diesel, mineral spirits, and wintergreen. Perhaps a few other things. Think it was some go kart recipe. This ring a bell with anyone and anyone know percentages? I've read the wintergreen oil needs some sort of carrier to get into the rubber. I like the idea of wintergreen, as it's what's used in topical ointments and was also considering using wintergreen with rubbing alcohol. Would be nice also to know the diesel/wintergreen/mineral spirits combo for break in. Traction was unreal
JAE is offline
Old 03-28-2017, 01:26 PM
  #28
JAE
I have a huge bottle of Wintergreen. How much do you use, and what do I mix it with? Someone at the track said my car would smell like hemerrhoid cream
JAE is offline
Old 03-28-2017, 04:05 PM
  #29
It never ceases to amaze me the crap people will expose themselves to just for a tiny bit of grip on a toy car. Most of the stuff being used is pure mystery sauce... while others are mixing belt dressing, diesel fuel, brake cleaner (!), mineral spirits, etc.
Really?
Jason B is offline
Old 03-28-2017, 05:04 PM
  #30
JAE
That's why I liked the oil of wintergreen and alcohol as a carrier part. Oil of hemorhoid cream (wintergreen) plus rubbing alcohol seems pretty non toxic and would be nice for a quick break in. Although, I'm not opposed to mixing in some diesel or turpentine laying around the house for a quick fix to soften tires when I've got a race 2 hours away in the AM with brand new tires.
JAE is offline
