Vision Racing Products (VRP)
#406
I've had vrp pistons awhile. doing a shock rebuild it occurred to me this valve is floating and must need a rebuild or to be replaced at some point. What's the racing life (2x per week) of the valve and does it make sense to replace the whole piston? Think I only saw hard valves separate. Thx!!
#407
I personally have ran a set for over a year with zero issues. Running twice a week, You are good for a while. If for some reason you ever needed or wanted to replace them, just send us an email and we will be glad to send you some.
The hard valves are a tuning option. They are something to try on a high bite track, as they slow down the rebound.
#408
Thanks! BTW - you guys ever mix the EU with regular pistons? KYO doesn't have a 2 hole 1.7 piston so was thinking of doing the EU front and regular Rear in a separate set of shocks? I understand some are for higher vs lower grip, but can you elaborate on the real world difference feel between the two? Running medium/med-high bite clay on treads in buggy thx!!
#409
#410
#411
VRP 'X' Pistons 2 Hole 1.6mm
#412
y'all have got me on the train and I just placed an order for 1.4 3 hole eu's for my b6 rears as I'm on super high grip astro. I figure it's worth a try and we'll see if it helps settle things down.
Looking forward to finding out!
#413
Got it. Thanks guys.. here are some comparison pics from xb2 to b6 chrome units. 23 and 27 lengths. They are pretty close. Threads are shorter on associated.
#416
Currently use 1.6 2 hole front and 1.4 3 hole rear. What would the impact of having 1.4 3 hole fronts have? I dont know much about what the additional holes do for pack and if that added pack/velocity of oil movement will limit steering at higher speeds, etc. anyone opine? thx!
#417
Looks like the associated kit has washers that won't go in the bottom like instruction prescribe. Anyone else run into this?
#419
They are in! The AE v2 pistons are too loose for the xb2 shock bore. Hopefully when dedicated pistons come out, this will be fixed. As they stand, accelerated wear might be possible.
2 hole 1.6 and 1.4 3 hole in rear. 25wt associated oil all around.
Lengths are close to xray and can be manipulated. I'm gonna shorten the fronts, my springs are loose at full droop.
#420
