Old 12-24-2005, 07:11 PM   #1
kartermdb's Avatar
Trader Rating: 15 (100%+)
Default Novarossi P5
anyone out there have decent needle settings for the stock 3 needle carb, mine seems to bog at WOT after it gets warmed up
Mark Burt
Thanks to:
TRINITY - Revtech - Awesomatix USA - Side Piece Racing - Roche RC USA - Darkside Motorsports - Genesis R/C Raceway
kartermdb is offline   Reply With Quote
Old 12-24-2005, 08:50 PM   #2
1armed1's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to 1armed1
Fatten the top, it's to lean.
Dayton
1armed1 is offline   Reply With Quote
Old 12-24-2005, 08:53 PM   #3
SpeedBump57's Avatar
Discribe the bog you are having at WOT. Don't touch the middle!
SpeedBump57 is offline   Reply With Quote
Old 12-24-2005, 09:05 PM   #4
kartermdb's Avatar
basically at temp (210-220), it runs good then it seems to shut off for no reason, im not tuning for power yet cause its a new engine with less than a gal through it, both mid and low are flush, and top is 4 turns
Mark Burt
Thanks to:
Old 12-24-2005, 09:11 PM   #5
Sofast-NT's Avatar
Sounds like a lean bog.What plug are you using?MC-9 works really good,and so does a Odonell 99.
Also what pipe do you use.I run a 053 on my P-5s,they make good power combined.
Sofast-NT is offline   Reply With Quote
Old 12-25-2005, 10:27 AM   #6
SavageSYNTH25's Avatar
Send a message via AIM to SavageSYNTH25
For a P5, the bottom probably shouldnt be flush. Try to go a little leaner on the bottom. I dont touch the mid needle unless the engine is too rich at idle and the idle increases because of too much fuel entering the carb.
P5's are really stubborn to tune if your low end isn't close to perfect. Try race tuning the top first, and then lean the bottom so the engine drops right back down to idle.
BTW: With the Nova P5's, 4 out on the top is about 1/4-1/2 richer than it should be.
All engines run differently, just do whatever works for ya. You could always go back to stock settings and re-tune.
SavageSYNTH25 is offline   Reply With Quote
Old 12-26-2005, 10:44 AM   #7
Sofast-NT's Avatar
Never had any tuning issues with a P-5.
Once you get the bottom end set,it should be pretty easy to tune.
Goodluck
Old 01-17-2006, 04:34 PM   #8
Trader Rating: 28 (100%+)
Instead of making a new thread...
Everybody around here runs their P5's with a king head or whatever. Is this just for bling, or does the motor need the extra cooling of the big head? For offroad 1/8 scale.
jbrow1 is offline   Reply With Quote
Old 01-17-2006, 06:20 PM   #9
Just bling IMO!
Old 01-17-2006, 06:52 PM   #10
Trader Rating: 20 (100%+)
Running the new Pro S3 Nocer head on mine, it do make a difference at the 100 deg races. The coating doesn't were near as much as a stocker.
http://www.teamnocer.com
Brandon Powell is offline   Reply With Quote
Old 01-18-2006, 08:59 AM   #11
layedbackguy's Avatar
Send a message via Yahoo to layedbackguy
My needles were way off from the factory so If you are having trouble tuning it at any time the high needle should be about 3 turns out from closed and the low 5 turns out from closed. If you ever get in a bind with tuneing, just go all the way closed on top and bottom and follow those settings...you should be good to go everytime..
layedbackguy is offline   Reply With Quote
Difference between Novarossi 51603 tuned pipe and Novarossi RB x12 tuned pipe? racer rich Nitro On-Road 8 11-06-2010 07:52 PM
FS: 1/8 Kyosho Evolva + .21 Novarossi 359 + Novarossi .21 pipe + Tons of spares WogBoy Australia For Sale/Trade 6 05-15-2008 06:32 PM
Novarossi Plus 21-5KT (Turbo Plug) New in Box, AND Novarossi 21P5XS less than 1/2 gal nobike R/C Items: For Sale/Trade 29 04-01-2008 12:00 AM
Novarossi N528XR and Novarossi EFRA-9853 For Sale BAMF90 R/C Items: For Sale/Trade 9 10-11-2007 09:29 PM
NOVAROSSI 367 PLUS 2 pink_sleeve Electric Off-Road 3 05-24-2007 05:20 PM
