Kyosho Ultima RZ6
#108
This car really is basically cheating on carpet in mod class. First race out with it and got a tq and win in the A main!
#109
If anyone is after a RZ6 give me a shout. Have a very clean one that has been converted to a RZ7. So all the RB7 and RX7 front and rear bits installed. Pro painted shell, used for 20 mins and shoo gued inside. Includes all the original parts.
Drop me a Pm if anyone is interested.
#110
Hey, guys just bought a used chassis anyone have a decent carpet setup for a converted RZ7? Currently has a gear diff with unknown weight for fluid. What is a good 17.5 gearing to start with? I've also read about moving the esc to behind the motor. Is that the preferred layout for carpet? Thanks.
#111
I have my esc in front, hearing for my fantom 17.5 is 72/27. I’ve copied setups from the rb7. Love my car but it’s lacking on my tight track. Chassis is a little too long. I have my f/r shocks similar to rb7 setups. My main concern was getting my motor to be fast, I feel that the traditional 3 gear has more punch. A b64 fan mount is beneficial in keeping the more running cool
#114
I finally got around to running the buggy. I had to change the springs to a little harder ones and went up in shock oil. It seemed to start to handle pretty well.
I did have a problem where my brand new 17.5 motor seemed gutless on the bottom end and had no punch at all. Went up and down in gearing and it didn't seem to help much. Has a brand new lipo too. I messed with the slipper thinking that was the problem. But now I think I stripped a gear in the diff. So that will come apart and get new diff oil. It seemed like the buggy had torque steer or something at the beginning of the night, so I keep messing with the slipper. But it was probably more tires, since I tired a different set.
My Rb6 has way more punch. I've read that this buggy doesn't seem to have good low end in 17.5. Why would that be? The drivetrain is really smooth and free. I was thinking of swapping all my electronic from my RB6 over to the RZ and see if that helps. If not I guess it will get a mod motor.
#115
I would be curious to see how all the rotating drivetrain parts between the rb6 and rz6 compare on a gram scale. it may be enough to cause the “sluggish feel” you and others have noticed.
#116
I just pulled the gear diff out and noticed that it is a metal ring and pinion gear. I didn't know it was metal. I thought I stripped some teeth, but i found out it didn't have some screws in the case were it should have, so that is why it must have messed up the mesh.
Is the metal on metal gears how they come in the kit? It does seems kinda heavy, so that might be one issue.
What side of the gear case should the ring gear be on for a gear diff? I have it on the right side of the case like the manual shows and now it runs in reverse.
I switched out all my electronic with my RB6 that I know work good, so I'll see how the torque is next time out. I put the other motor in the RB6 with the same gearing it was before to rule out the motor.
#117
The metal gears are what came with the RZ6 conversion. It's a gear diff. If you run on dirt you can swap in a ball diff from the 4wd cars. But you will need to use other parts from the 4wd as well (see the manual).
Since it's running in reverse, take the diff back out and flip it over. Use some white grease on the gears too, makes a huge difference.
#118
I'm running carpet, so I need the gear diff. I have a few ball diffs from my Lazer zx5 4wd I could try if needed. So I take it a gear diff goes in the opposite way as a ball diff? Because, I checked my TF5 and Zx5 manuals which are ball diff and the online manual I found for the rz6 they all have it the same way, right side.
#119
It all depends on motor placement on the chassis. The zx5 has the motor up front. Starting with he zx6, they give the option of moving the motor to the front or back of the car. The RZ has the motor at the back, so it should spin the drivetrain the opposite direction. But just flip the diff in the case (rechecking your mesh) and you should be good.
