Help XRAY XB4 16' - Steering knocks out of whack - can't find source
Help XRAY XB4 16' - Futaba BLS571 - Steering knocks out of whack - can't find source
I have an XRAY XB4 16' and when I crash or hit something with my front wheels, the steering gets knocked out of whack basically everytime I wreck or hit anything.
Let me start by saying I already have an aluminum Hudy servo horn.
At first I thought it was was the servo saver, so I tightened it...kept occuring. Then I thought it was maybe the turnbuckles...kept happing, so I started measuring them to check. Again I turned to the servo saver...so I bought the aluminum exotek steering cranks. Now even with the alum cranks it still does it.
Also when I hit, both wheels and cranks appear to be out of whack equally. Which seems to make me think it is potentially the servo because if it were anything else most likely one side would be out of whack, not both equally...
I have a $160 Futaba BLS571 brushless servo. Is it possible that the servo is jumping gears inside? I checked the servo horn, and that doesn't appear to be mucked up or slipping. The servo sounds normal and seems to work fine.
I can't figure this out for the life of me. Any thoughts?
I have an XRAY XB4 16' and when I crash or hit something somewhat hard with my front wheels, the steering gets knocked out of whack.
Servo is not moving? tighten down to chassis (are you using a floating mount? Could be bending).
Servo horn? use a clamping servo horn. Make sure the servo horn is not bending.
Ball ends? make sure all ball ends are secure and not bending and not shifting (including the camber and steering)
Make sure the shock tower and bulkhead (upper and lower) are not moving- look for shifting camber as that also affects steering center.
Make sure your hinge pins aren't bent- if they are bent they will rotate around, changing the arm angle and thus the steering center.
Are you using alum screws in the bulkhead or tower? When they bend they change camber geometry and there goes steering center with it.
Been there done that
Good luck!
Are you having to re-centre the servo horn on the servo? The XRAY kits ones are made from cheese, so that may be slipping even if it doesn't look too bad. Try an alloy one.
Sounds most like a stripped servo horn.
Happened with mine very quickly, looked good, but wasn't.
Replace with an aluminium one ASAP.
If you get a hudy one, you need to shorten it as they hit the body on the '16
mine just done same ,its teeth in servo,start car turn servo full lock & hold wheel to stop it from centring it will make horrible noise & I bet it stripped teeth at full lock. depending on servo u can go in rotate stripped section of gear a certain degree so teeth don't get used when operating ,if u can be bothered.
I've never owned an rc car or truck that the steering wasn't throw off when it was in a good wreck. Just say'in..
Could be many other things still. I would also check;
Good luck!
Good luck!
I am already using the hudy aluminum servo horn, I should have mentioned that.
Why does this expensive futaba servo jump gears so easy if so? My savox never did this to me! I thought the Futaba would be even better!?
It's not just huge wrecks. It's mostly any wreck or any time I hit my front wheels on a pipe or clip a wall, not even head on just a little bit, it happens WAYYY to easy and it's happening easier and easier now.
Yes, I just stated that and I edited my first post. Forgot to mention that, but honestly that would be the first place I turn before checking anything else.
Also, I'm remembering the first time my wheels went out of whack. I took a huge wreck where I hit a big jump going really fast (5.5t motor) into a corner and landed a bit off center, lost traction for a second, then went to make the corner and the outside wheels caught traction (astro) and I traction rolled, then the car turned from a roll to a cartwheel maybe 5 times and one of the time it bounced 3-4ft high (picture the way a football tumbles) and landed on the pavement like 20ft away!!
That one torqued my steering out of whack (as expected) and ever since then every little hit knocks my steering out of whack. I had to have sheered some teeth on my servo. which is weird because it doesn't appear to be loud or not functioning under normal use. And quite honestly, I've taken harder crashes with my Savox (at least for the servo), I've ran into a wall at the end of a big straight into a tight corner and popped a ball cup and tweaked some stuff. Servo was fine. Are these Futaba servo's weak?
That one torqued my steering out of whack (as expected) and ever since then every little hit knocks my steering out of whack. I had to have sheered some teeth on my servo. which is weird because it doesn't appear to be loud or not functioning under normal use. And quite honestly, I've taken harder crashes with my Savox (at least for the servo), I've ran into a wall at the end of a big straight into a tight corner and popped a ball cup and tweaked some stuff. Servo was fine. Are these Futaba servo's weak?[/QUOTE]
A lot of the Futaba metal gear servos have one plastic gear in them to protect them. It acts like a servo saver in a way. You need to pull the servo out and apart, inspect the gears to see if they have any damaged teeth. If there is a plastic one, more than likely its damaged.
I guess I was wondering if there was any other source besides the servo that could account for my situation. And if not if anyone else has had this happen to their servo more specially the Futaba BLS571
You have to read the thread man I said both wheels are out of whack equally and Iv taken everything apart multiple times measured put back together. There's no possibly way one of anything is bent because both wheels and steering cranks are equal. Furthermore everything is perfect once I recenter.
But I'm the a hole carry on friend.
