Broken torx in hex retainer >
Old 06-01-2016, 09:40 PM
it_rc's Avatar
Default Broken torx in hex retainer
The tip of my torx broke off inside the retainer screw of the hex adapter on my MIP X-Duty CVD's. Suggestions on the best way to salvage the most parts so I don't have to by a new rear axle AND bearing carrier? I have drill bits small enough, but I don't have confidence in the bit not breaking or even being strong enough since the material densities may be equal. The unfortunate thing is that I put it on way wrong and it's entirely too tight.
Thanks!
Attached Thumbnails Broken torx in hex retainer-2016-06-01-20.49.52.jpg   Broken torx in hex retainer-2016-06-01-20.48.43.jpg
it_rc is offline
Old 06-01-2016, 11:15 PM
ekt
ekt's Avatar
I'd try applying lubricant and knocking the axle though the hex with a hammer.
ekt is offline
Old 06-01-2016, 11:45 PM
it_rc's Avatar
Great idea. Thank you.
it_rc is offline
Old 06-02-2016, 04:17 PM
Drill into the grub screw, use a small enough bit that you mostly attack the broken driver tip, and not the grub. Then, use a broken screw extractor to remove the grub screw.
I've had to do this before.
WindDrake is offline
Old 06-02-2016, 05:33 PM
Try Freezing . then go @ it with dental pick.
SerpJimmy is offline
Old 06-02-2016, 06:48 PM
Trader Rating: 275 (100%+)
Cutting a slot w/dremmel using a cut-off wheel and use a flat tip screwdriver sometimes works.
Andy Koback is offline
