TLR 22-4 2.0 Race Kit Thread! >
Like Tree243Likes
    Hide Wikipost
Old 06-20-2016, 06:37 AM   -   Wikipost
R/C Tech ForumsThread Wiki: TLR 22-4 2.0 Race Kit Thread!
Last edit by: Kraig
Here are some good build tips and notes from b1narych0ice (thank you):
Specific build step comments/warnings, including areas I replaced stock parts -- Think of this as a FAQ that answers questions I had from other builders about each step:
A-3: You can instead use TLR Aluminum Servo Mount here.
A-5: Be sure to get the shorter screw in the correct hole.
A-6: Use a 76 or 78T spur if you are running a 13.5T-21.5T motor instead of the 84 in the kit! and...
A-6: The plastic washer between the pulley and the thrust assembly should be oriented so that the flat side goes toward the pulley, and the side with the ring goes towards the thrust assembly's metal washer. Diagram in instructions is correct, you just can't see that this washer isn't flat on both sides from the illustration.
A-7: Be sure the nut holding the Full-Time 4WD assembly is nice and tight, I have seen it get loose in the 1.0 car!
A-9: Put the gears on the jackshaft before the c-clips, so that you don't have to deal with getting the c-clips off to put the gears on
B-2: It seems to be possible to push the outdrives on so tight that they bind when spun, be sure to ensure that they spin freely as the manual notes.
B-7: You're screwing the 1.3mm screws into metal, don't crank so hard you strip the heads on the screws. While this is metal-on-metal, the manual doesn't call for loctite here.
B-8: The rear diff has fewer/bigger teeth, the front diff has more/smaller teeth.
C-3/C-4: TLR Aluminum Bellcranks and Exotek steering rack can be used here to increase durability/reduce steering slop
C-8: TLR Aluminum A/B Horn can be used to increase durability/reduce steering slop.
D-2: Don't worry about the kingpins sticking out the front even when the nut is tight, the bumper will push them in and keep them there.
D-5: Shock tower screws were the tightest plastic part on my kit, look from the side when tightening down the tower at the gap between the tower and the front bulkhead, tighten until this gap is closed.
D-6/D-7: Don't mix up the CVA pins and the hex pins, should be easy because hex pins are black and CVA pins are silver.
D-8/D-9: Use a toothpick to get threadlock in the metal block instead of applying it to the shoulder bolt, so that you don't get it between the plastic spindle and the metal block.
E-1/E-2: Don't mix up the 10mm pins for the rear hexes with the 11mm pins for the rear CVAs! They are packaged together and both silver, so it's easy to think you just have 4 pins that are the same!
G-1: No need to install the post on the right side if you are running a shorty and use velcro to attach the body to the mud guards. You can move the right post up or down a little so that it snugly fits your shorty battery.
G-2: Aluminum Servo Horn can be used here.
G-4: Adjust the length of the link and the servo horn position so that both the servo horn and the horn on the bellcranks are parallel with each other, and perpendicular with the link.
Hope this helps some of you that are putting your kits together, and thanks to Frank and the TLR crew for a solid kit!
Driveshaft Update from Frank - I've reviewed some parts today from stock. The 'issue' part is definitely the rear CVA driveshaft bone. The pin slot is not 90* to the bore for the barrel. We are working to get good parts made and here for CS use ASAP.
Some of the parts I checked were not 100% free, but definitely run-able. Keep in mind that the driveshafts should wear in fairly well, and quickly (within a few packs). If you have a 22-4 2.0 and are experiencing issues with the driveshafts, we won't have good replacements for probably a couple of weeks (no definitive timeline yet), so I would recommend running them on track for 1-2 packs, then rechecking. I think most will free up well.
I am sorry that we are having an issue. Everything was great during samples until production, but we'll make sure to get it right, and make it right for those with the bad parts.
What is the proper level for the diffs...i am used to building 8th scale diffs, i would assume its the same?
Just under level. You need some room for the output gear that is in the cap.
Frank can u explain what is the difference between the a and b horn, TLR331018?
It isn't the horn, it is the ackermann setting. B will have less off power, better mid corner steering. A will have more off power steering, less mid corner.
Print Wikipost
Old 11-22-2018, 07:33 AM
  #2311
Trader Rating: 23 (100%+)
Sorry zeke not seek
Jfowler is offline
Old 11-26-2018, 01:24 PM
  #2312
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
Originally Posted by Jfowler
what body is seek ballenger running on his 22-4 2.0 I’ve looked and can’t find one that matches that style
It is the new Low Profile TLR body. Coming in 5-6 weeks.
90sRacer likes this.
Frank Root is offline
Old 12-06-2018, 04:28 PM
  #2313
Does anyone have a link to JR MITCH carpet setup I've looked on the tlr website with no luck, Thanks
j.gurnitz is offline
Old 12-07-2018, 07:31 AM
  #2314
Setups | JR Mitch Blog
freebird is offline
Old 12-07-2018, 07:45 AM
  #2315
90sRacer's Avatar
Default Low Profile Body
Hey all. Just a heads up about the TLR Low Profile body....it’s available on Horizon, or ask your local shop that carries TLR products for part number TLR330009.
90sRacer is offline
Old 12-14-2018, 10:07 AM
  #2316
Beau S's Avatar
They are now in the wild!
Beau S is offline
Old 12-14-2018, 10:36 AM
  #2317
90sRacer's Avatar
Indeed! Just finished painting mine last night! Can't wait to get it on the track this Sunday.
Beau S and RazorRC like this.
90sRacer is offline
Old 12-14-2018, 10:40 AM
  #2318
Trader Rating: 380 (99%+)
The old body was nice, but getting long in the tooth. Glad to see the new low profile body is finally available to us weekend warriors. My only downside to it though, I think it's proof that a new wheeler is nowhere in the works. Why create molds for a car that would be getting replaced anytime soon? Looks like the 20+ year old design is here for longer.
RandyJones likes this.
jonski is offline
Old 12-14-2018, 10:42 AM
  #2319
Beau S's Avatar
That paint scheme looks good with this body!
Beau S is offline
Old 12-14-2018, 10:49 AM
  #2320
90sRacer's Avatar
Thanks! I wish I had better paint skillz.
90sRacer is offline
Old 12-14-2018, 04:14 PM
  #2321
Beau S's Avatar
you can take most 2wd buggy bodies, & they’ll fit on other brand cars. This body does match the side guards, but you’ll notice areas that are taller, more underbody clearance, where a lot of changes “could” be made w/o needing a new body mold. JS
Beau S is offline
Old 12-20-2018, 05:30 AM
  #2322
Hey all! I'm going to be selling the buggies I currently have (Sworkz S12 and S14-2) and am going to be getting a new 22 5.0 and am also looking for a 4wd buggy. How is the 22-4 2.0 on astro/indoor? I had a XX-4 back in the day and absolutely loved it! TIA!
packhntr is offline
Old 12-29-2018, 11:41 AM
  #2323
With the lockout how tight are you guys running the belts. I’m experiencing belt skip on the step down section in the current layout on my home track. What belt setting should I be running? Thanks
bigdog is offline
Old 12-30-2018, 12:42 PM
  #2324
Team Pink's Avatar
Trader Rating: 20 (100%+)
Every time I have ran 13.5 with the Exotek lockout Ive ran the standard front belt settings and B (arrow pointing back) in the rear. Same tensions I run in mod with no issues. Also make sure your belts in good shape. Worn out belts can skip as well.
Team Pink is offline
Old 12-30-2018, 03:44 PM
  #2325
Trader Rating: 26 (100%+)
Tyler’s paint looks awesome on the new body!
RandyJones is offline
