Team Losi's Baja Rey Thread
#586
#587
My son has been running 3s from day one. Now when he gets hard on power it sounds like gears are stripping. I pulled the front case apart and seen no signs of metal. Pulled the 3rd member out and the same result. I pulled the bottom plate off of the bottom and looked at all the gears and they all looked fine...anybody have this issues. Pinion bearing in the rear looked and felt fine. The only other issues is the front tires are ballooning real bad. Thanks for the help in adavance
#589
#591
I got to do a full run this past weekend on a nice area of frozen grass with some little bumps. i really love this truck. Sure it doesnt handle as well as my other cars, and it isnt as fast, but it truly is a lot of fun to drive this.
i was able to find a nice s6040 servo 2nd hand and i ordered the aluminum servo arm to help with the slow servo it came with, and i will change the shock oil based on what is posted in here. i just am really enjoying this car. i am going to try to go out again tomorrow. i just wish it wasnt so cold out.
#592
#593
Ex newb
Hey guys/girls, just bought my Baja Rey, and I pretty new to rc, any advice as to where to find parts, accessories, any advice at all is welcome I don’t even have batteries yet..
#594
Ebay is also a good source. And has, for the most part become my parts source.
#595
any idea where to get number plates and mudflaps, what size battery and charger lol I literally just know that it looked cool so I bought it
#596
I just know I have seen pictures, of stuff that can be done to these, and they are pretty sweet when they are all dressed up, plus I don’t have a ex shop near me.. closet one is 2hrs away
#597
Sorry about that. Got sidetracked last night. This is the battery I use in mine. I also have a 3s from same brand. There’s not a lot of room so have to check size before. Plus the plug wires need to come out of battery like this. Not in the middle as some do.
#599
Hello. I have a question. Someone from the forum participants tried to unlock the rear differential?
I would like to unlock the rear differential and see how the car behaves with the unlocked rear differentials, but I cannot find gears suitable for this.
Guys, be careful when installing the rear differential. baja rey instructions for the wrong differential are drawn.
an incorrectly drawn installation of the differential gear is drawn to be installed on the right side, and in fact it is necessary to install it on the left side to prevent the wheels from spinning
#600
faced with a problem when replacing the rear propeller.
Cardan SSD RC Rock / Baja Rey Scale Steel Rear Driveshaft was ordered
and in it the stud (M4 set screw) is slightly thicker than the standard stud from the cardan plastic.
And this pin (M4 set screw) does not fit in Pinion Gear.
It is impossible to bore a hole in the pioneer. The drill itself does not grind and the hole in Pinion Gear is not bored.
if you tighten the pin from the stock model, it turns out on the reverse side where there is no thread. It will not work
in theory, since the diameters do not match and will b **** dangle like a pencil in a bucket
What do you think to give back the cardan or somehow try to shred a hole or, in principle, twist the stock rod and everything will be fine
