2wd buggy for mod? Associated. >
Old 04-12-2016, 01:01 PM
  #16
Originally Posted by Justinmatt21 View Post
Thanks for the feedback.
If I went with the B5 RM what upgrades or things would you suggest that I need to do to be competive both indoor and outdoor?
Also, what turn motor would you suggest? I will be using the Reedy Blackbox 410r, as I am running this in my SC10.2, so would like to stay with a Reedy Mach 3 motor, just not sure what turn will be sufficient.
Thanks!
1. Practice is about the only mods you will need to be competitive with any race bred kit that you buy. Seriously. RM/MM.. If you are just starting out.. It doesn't matter.. Just get to the track and practice.
2. 7.5-8.5t... 7.5 for 4 gear & 8.5 for 3 gear.. IMO..
Rabidtrout is offline
Old 04-12-2016, 01:55 PM
  #17
JAE
Trader Rating: 30 (100%+)
Personally, as a fairly noob myself, I'd rather keep with the times and mod the mid motor with weight for the outdoor track than vice versa. Stick with the times. Lot's are now even moving to laydown transmissions now... get a mid motor, couple steel/brass parts or weights for the rear and call it a day and just practice....- a fellow newb's 2cents..
JAE is offline
Old 04-12-2016, 02:10 PM
  #18
tc5 man's Avatar
If its lower traction outdoors the 4 gear mid motor would work better than 3 gear.
tc5 man is offline
Old 04-12-2016, 02:13 PM
  #19
You can also add the SMC weight system and use MM for outdoors. The CE maybe a good choice since it gives you the 3 and 4 gear.
http://www.smc-racing.net/index.php?...product_id=278
Chris Reilly is offline
Old 04-12-2016, 02:39 PM
  #20
Pinkz's Avatar
i watched a local outdoor dirt track race, asked questions and some observations from final 2wd buggy mains mod and stock. loose and dry to wet and muddy at times
stock had 3 sponsored drivers in it three ran B5 cars, two had motors in back finished 1st and 3rd and one forward finished second. they diced thru race, slower drivers had more of a impact on this race causing issues for top three drivers. lead changed many times due to this. one local regular driver had rear motor, rest all forward
mod...6+ mixed company sponsored drivers, all cars where forward motor, including regular drivers. a mix of 3 and 4 gear systems
Pinkz is offline
Old 04-12-2016, 02:49 PM
  #21
Suspended
Trader Rating: 61 (100%+)
Which track was this?
Interesting results!
Socket is offline
Old 04-12-2016, 03:38 PM
  #22
Thanks for the great suggestions.
I was just looking for folks suggestions and experiences before I spent money on a kit.
Now I just need to weigh all my options and make a decision.
Leaning towards the B5M lite and adding weight when running outdoors.
Justinmatt21 is offline
Old 04-12-2016, 07:47 PM
  #23
Devin's Avatar
I would buy a used Durango dex210. Good rollers regularly sell for $100 with parts/tires.
Has a good mid motor and rear motor set-up, so once you get the hang of driving you won't have thoughts like: "if only I had a rear motor car outdoor's I would have won that race". You get to try both for the same price and see what you like / what your track needs. It also lets you experiment with 3 and 4 gear transmissions, so you can learn what you like there as well (I like 3 gear everywhere).
The car is great, though you will have less people in the pits to help you than with Losi or Associated because of how common they are.
Devin is offline
Old 04-12-2016, 07:53 PM
  #24
Yeah Losi and Associated is popular in my hometown as well.
But they don't mind if I run Durango stuff. I was into Losi and Associated bigtime,
But I wanted to try something different and Durango was a better choice for me
because I used to run Tamiya TRF cars and people would get pissed if I beat them with a Tamiya.
So I ditched the Tamiya stuff for Durango stuff, which it was a pain to get Tamiya parts anyway.
bmag5000 is offline
Old 04-13-2016, 08:59 AM
  #25
Thanks Chris. I would definitely pick up the CE, however I can't find that model anywhere, since it has been discontinued.
