Reconstituting tires >
Old 04-11-2016, 08:56 AM
  #16
Super Moderator
racer1812's Avatar
Trader Rating: 31 (100%+)
Originally Posted by JAE View Post
Good to know. May have jumped the gun. Never seen tire like this before but have only been buying them 6 months or so.
Yes you did..
Originally Posted by Socket View Post
They're fine.
and yes they are.
Electrons haven't even been out long enough for a set to get "old and crusty"
racer1812 is offline
Old 04-11-2016, 09:32 AM
  #17
JAE
Trader Rating: 30 (100%+)
Default Re
No problem admitting when I'm wrong. Apology sent to seller. Thread was aimed at reconstituting tires and got carried away. Carry on
JAE is offline
Old 04-11-2016, 09:46 AM
  #18
Super Moderator
racer1812's Avatar
Not a huge issue, other than your seller might think you're a bit of a nut job
You'll see all different amounts of mold release depending on the brand of tire. And some is easier to remove than others. Just make sure you remove it all from the bead before gluing. The best way to do that, opinions vary. Everything from Simple Green, Windex, motor spray. I personally use PVC pipe cleaner, which is mostly Acetone.
Old 04-11-2016, 10:28 AM
  #19
JAE
Default Will do
Thx
JAE is offline
Old 04-11-2016, 06:04 PM
  #20
thecman26's Avatar
Trader Rating: 100 (100%+)
+1 they're fine!
Scrub that off with simple green and a scrub brush.
thecman26 is offline
Old 04-11-2016, 11:06 PM
  #21
i thought that rubbing alcohol isn't the right stuff to clean them with... wont that promote them drying out?
jimbo74 is offline
Old 04-12-2016, 07:32 AM
  #22
Suspended
Trader Rating: 61 (100%+)
I wouldn't worry. I'd clean the beads with simple green, glue'em up and let her eat.
Socket is offline
