Serpent SRX8-E
#526
I've been trying to get one for a while now but its out of stock.
you can turn the plastic part to go from rear arms and cut it so it doesnt touch the arms.
#528
#530
I run only the plastic inserts on the front arms and none for the rear so the rear will have more flex and traction.
#531
1st club race win 🙃 wohoo
my go pro angle was a bit off 😬
#532
What are the most common parts that break on this buggy? I got the RTR version and wanted to casually club race it. I used to race nitro buggies 12-15 years ago and know the front end takes the brunt of the damage.
The RTR has a somewhat thin front shock tower, so I'm thinking about getting the thicker kit version shock tower. The RTR shock cap ball mounts are plastic, so I may upgrade at least the front shock caps to all aluminum. What else is a weak point?
#533
buy a used kit for $200 ish and swap the electronics over…
#535
#536
is there a parts list to convert an srx8 to electric?
#538
#540
Yes, that's too thin.
I typically run 550 Front and 500 Rear with pink springs and as the day get warmer or traction gets higher I go thicker weight and usually jump up 50 at a time.
So for example if I start on 550/500 and traction is higher or the day gets warmer I'll move up to 600/550 and even have gone to 650/600 a couple times as well on hot days.
