Proline prime on "HIGH" traction clay >
Old 03-06-2016, 12:34 PM
Lowe's48's Avatar
Default Proline prime on "HIGH" traction clay
Hey guys.
I run on very hi traction clay i mean like carpet(with Tekno sct410.3) !! I'm running Proline prime(clay) and no matter what i do to get traction out of the chassis they are still too much. I like my car(sct) a little on a loose side to suit my driving style.
What methods do you guys do to the tires to get some grip out of it ? I know its kind of a odd question !! most would be asking for more grip
Lowe's48 is offline
Old 03-06-2016, 12:39 PM
Suspended
Trader Rating: 61 (100%+)
Just so we're clear, you want less grip, right?
Switch to sanded down proline clay electron. Adjust how much tread left by how much less bite you want.
Socket is offline
Old 03-06-2016, 12:54 PM
Lowe's48's Avatar
Yes less grip.
What do you use for sanding ?
Lowe's48 is offline
Old 03-06-2016, 01:03 PM
Dan.J's Avatar
Trader Rating: 21 (100%+)
Have you tried simple changes like moving rear hubs back for longer wheelbase?
Dan.J is offline
Old 03-06-2016, 01:39 PM
Suspended
Originally Posted by Lowe's48 View Post
Yes less grip.
Sand paper.
Socket is offline
Old 03-06-2016, 01:43 PM
change to a less grippy tire?
jimbo74 is offline
Old 03-06-2016, 02:19 PM
M4 ions might do the trick..
rannblod is offline
Lowe's48's Avatar
Lol I wish it's that simple !!
Everyone is running prime. I mean i podium every time out but stuck at 2nd and with my driving style i need it to be a little looser in the rear so i can push harder. I feel like i can only push at 85% at the present time and if i try pushing above that the grip will bite me !!
Lowe's48 is offline
Old 03-06-2016, 02:22 PM
Lowe's48's Avatar
I was thinking the same.
Lowe's48 is offline
Old 03-06-2016, 02:23 PM
Lowe's48's Avatar
Sand paper.
Would that work on prime as well ??
Lowe's48 is offline
Old 03-06-2016, 02:27 PM
Lowe's48's Avatar
I sure did Dan.thanks
I don't think you guys understand how much grip this clay has!!
I mean literally like glue. my 1/8 superlite running 20 mm ride height and will traction roll if i push too hard.
Lowe's48 is offline
Old 03-06-2016, 02:28 PM
MaricopaAgent's Avatar
Trader Rating: 28 (100%+)
yup. change tires, maybe even a harder foam.
and or camber links..
MaricopaAgent is offline
Old 03-06-2016, 02:33 PM
Lowe's48's Avatar
Camber links has been tried. I like to change tires as my last resort.
Anything i can do with the prime to take some grip out ??
Lowe's48 is offline
Old 03-06-2016, 02:58 PM
Suspended
Yes. Buy a Hudy or other brand tire truer and cut tread into them. Cut out the sidewall and try a firmer foam, like a JC gray.
Socket is offline
Old 03-06-2016, 03:27 PM
I can relate I ran some super soft proline primes heavily marinated and sauced.. My t4 would traction roll just thinking about pushing around the corners.. I stopped saucing and after a day of practice the finnaly calmed down. Still grippier than all get out. I ran ions on my scte soft compound and could drift get loose in the corners a little to lose.. Never had the chance to use the m4 ions I'm sure they would have been perfect.. Sold the scte I miss that truck.
rannblod is offline
