Proline prime on "HIGH" traction clay
#16
I had a similar situation and I ran primes on the front and barcodes in the rear.. Once I got used to the super high grip I put the rear primes back on..
#18
What are you running in the diffs?
#19
Lol I wish it's that simple !!
Everyone is running prime. I mean i podium every time out but stuck at 2nd and with my driving style i need it to be a little looser in the rear so i can push harder. I feel like i can only push at 85% at the present time and if i try pushing above that the grip will bite me !!
Goint to a different compound perhaps maybe M3 or M4?
#20
I can't get the Tekno site to work right now, I think it's down but look up the Jesse Munn DiehardRC astroturf setup. They are running fat 2.9mm anti-roll bars, and stuff that I think will help you on a very high bite situation. Jesse and Keith (another Tekno driver) are extremely fast guys - I think you'll like what they have done with their trucks.
You can find his racer page here: https://www.facebook.com/jessemunnrc/
#21
#22
#23
#24
My home track is medium grip I would say, Primes in MC work very well when sauced, I tried some Primes in M4 sauced this morning and buggy was on ice.......very loose. Maybe with your track being super high grip some M4's would loosen it up some? Keep in mind our indoor track temp is only 50ish degree's right now in the track area so not sure what your situation is just passing on what I seen today. It was weird to me though because my thoughts was low track temp go softer on the tire.......didn't work at all with the slicks for me anyway.
#25
Thanks Dan,knowing what i know now i would have try the Prime m4 first. But i'm kinda want the see what i can do with this set before i spend anymore.
May be a little light sanding will help??
#26
curious, the m4s aren't those like the super soft compound, wouldn't the clays be less grippy or am I missing something?
I general when I have wanted to free up the rear more, I usually look to raise up there rear camber link on the shock tower, that usually helps. When I ran my tekno on high traction carpet using schumacher mini pins, it was planted and wouldn't roll, but I could still turn on the dime.
#27
Matter of fact I just did raised the rear camber link in the main Saturday and it was even more hooked up caused me to have to slow down to preventing me from rolling at the end of the straight at 20/21mm ride height but still came in third.
I have got to figure this out, I really hate driving at 80% it's no fun!!
#29
Yes Cain, the m4 are super soft. And in my case that would help loosen the car up but I'm trying to work with what I have for now. Not given up just yet.
Try posting your setup, may help.
#30
I think if you are trying to tune a bad tire option it will have you chasing yourself, 90% of the set up is in your tires. here in phoenix we have some seriously high traction clay and clay primes are the option for many as well as the jc smoothies. I tried a set of super softs as I had them from another track and it was stupid trying to drive those tires. another problem we see are that our foams wear out long before the tires show any significant aging, so keep that in mind as well.
I know throwing a set of tires into the maybe I will use it one day bucket hurts, I have a few sets of tires there as well but finding the right tire choice is the most important part and also prepping that tire. ask the local fast guy what he is doing or to help you prep a set. I have even asked to borrow a set of tires to try so I could feel before I buy them most guys will let you do that hell if the fast guy has a tire sponsor his old worn outs are probably better than my new ones lol cause he preps them right.
