nova p5xt vs plus 21t
is the plus 21 the fixed version p5x heard some storys about leaky front bearning on the p5x
besides the plus 21 has larger crank touch more rpm/power and oh yeah price both engines seem identical
They look identical,but the plus is a 8 port monster.I have never heard of a Nova motor with a leaky bearing.
I know V-Specs have bearing probs.,and people replace them with a Novarossi bearing.
Hope this helps.
Land
Hope this helps.
Land
The p5 plus is a 5 port engine , only difference is the rear bearing has a larger diameter 25.4mm to 25.8 mm and the idle screw is now on the opposite side so it is easy to get to and yes the crank is .5 mm larger. as far as leaking bearings ? Yes NovaRossi did have a problem , due to a bad seal material ,it would shrink from heat , now all the new seals are blue , if you have a black one REPLACE IT !
RB Concepts even had bad bearing seals . So pay close attention to your seals on the front bearings.
The new Plus version is supposed to be a lot smoother from bottom to mid range , the regular P5 was an animal !!! If you want super smooth power use the 421 B , It screams incredible RPM yet is silky smooth EVERYWERE ! From idle clean to the moon ! I have never driven a smoother more powerful engine ! I have a modded RS 7 Crono engine and it is utterly insaine powerful but the 421 will eat it alive on the track because it is so easy to drive !
