Kv confusion?
I'm pretty sure I have a decent understanding of what kv is. (RPM/volt)
I was looking at the thread about what kv is used in 1/8 buggy and truggy. For some reason people say that the most common for buggy is around 1900 and 2250 for truggy. I'm confused because if truggies are heavier then wouldn't they need the lower kv for more torque, which in turn gives less top speed? Help me out of I'm wrong.
Frequently the truggy motors are a longer motor, that provides more torque. For example the popular Tekin T8 truggy 2250 & 2000kv motors have a 77mm long can. The T8 buggy 2050, 1900, & 1700kv cans are 69mm long.
Thanks, I was wondering that too
1/8 buggies are typically ran on 4S batteries so twice the voltage results in roughly half the Kv needed which in turn produces similiar speeds to 2S but much more "power". Only do super light buggies (like the MIP Pro8) run on 2S needing a higher Kv motor 4000-4700Kv.
You also have to consider where you plan to run your vehicle (i.e. the specific track, layout, size, etc.). Ex. 1700kV is a popular kV for buggies because many tracks aren't that big, so there's no point in using a higher kV motor to get more speed that isn't needed and likely will be more difficult to control (have to control your throttle more carefully). Those small-medium tracks also aren't as popular for truggies due to the size (bigger vehicle on a smaller track). Truggies tend to be more popular at larger tracks where more power and speed can be used. Also, people tend to see truggies as better bashing vehicles due to more ground clearance and overall better versatility for more terrain types and bashers tend to like more speed (and have the area to use it), so higher kV.
Thanks everyone for all the help, I appreciate it.
