Gearing questions >
Gearing questions
Gearing questions
Old 01-31-2016, 11:16 PM
RockyMtnRc's Avatar
Default Gearing questions
I just upgraded my brushed 2wd slash to the castle creations SCT esc/ 3800 motor combo. Im enjoying the increased speed and power but I want to get a little bit more out of the system. I usually just bash on the pavement and drive on a dirt track, what would be optimal gearing for this? Preferably something that will up my existing speed compared to the stock brushed gearing for the slash. Thanks for looking.
RockyMtnRc is offline
Old 02-01-2016, 05:10 AM
RC Matt's Avatar
What are you running currently?
RC Matt is offline
Old 02-01-2016, 06:44 AM
38T Steel Spur Gear for 1/10 Revo mod 1 looking for the Matching pinion Choices going on my rustler vxl.
lighttravler is offline
Old 02-01-2016, 08:28 PM
RockyMtnRc's Avatar
Im currently running the stock slash gearing. 19 pinion 90 spur.
Old 02-01-2016, 09:44 PM
volt up, gear down is what i always say
cullyboy87 is offline
Old 02-01-2016, 09:46 PM
id go up 2 teeth on the pinion or down around 6 on the spur
Old 02-03-2016, 10:18 PM
RockyMtnRc's Avatar
Thanks, do you think this will give me the best speed torque combo for what Im looking to do?
Old 02-06-2016, 11:52 AM
It's brushless for bashing I'd just go up the two on the pinion and see what it feels like. You're not tuning it for a track so you're not gonna feel the "lack of torque" out of that tight 180 turn. Plus if you're bashing pretty much any jump you hit will be at a higher speep so you won't need that bottom end to make it. And castles are almost bullet proof so the slightly if any higher temps shouldn't be an issue.
CaseyD is offline
