Losi 8ight-T clicking sound from front end >
Old 01-30-2016, 05:18 PM
Default Losi 8ight-T clicking sound from front end
Guys, I just finished putting together my first Truggy (Losi 8ight-T, converted to brushless, used from this site) and did a trial run today. Under acceleration, if the wheels are turned fairly tight, I get a clicking sound. It happens under hard braking as well.
I have attached a link to videos that you can hear the sound in. (It won't let me post a link, too much of a rookie I guess!)
I just want to make sure I don't have an issue that I need to tear into.
By the way, this is not a dig on the used truck at all, I got a good deal and I know it's used, so no worries there.
Thanks, Joe
mossman2 is offline
Old 01-30-2016, 05:36 PM
Jerm13's Avatar
Trader Rating: 36 (100%+)
Thanks, Joe
Sounds like a bad ring and pinion on the front diff. May be stripped or may just be shimmed incorrectly. Usually, its the rear that does it more than the fronts, but they do skip teeth from time to time when worn.
Also, check the center driveshaft couplings. They also wear out and can cause all sorts of problems.
Jerm13 is offline
Old 01-30-2016, 06:13 PM
omgbilly's Avatar
Did you make sure to lubricate everything? Could be a bearing also. I agree that it's LIKELY diff related but it could be anything from the bearings to the diff.
omgbilly is offline
Old 01-30-2016, 07:06 PM
damang999's Avatar
Trader Rating: 15 (100%+)
only when wheels are turned tight? you mean steering ? my jc rims rub on my 2.0 truck when turning sharp and make a clicking sort of noise.
if its your diff you shouldnt need to turn to make it happen
damang999 is offline
Old 01-30-2016, 07:25 PM
spookie's Avatar
Trader Rating: 25 (100%+)
Check the cvd's, and make sure they aren't tight with grit or sand. What happens is it's tight, it "flicks" the inner dogbone against the cup as it rotates. Try putting some foam piece or tiny O-rings inside between the inner dogbone and cup, so the inside dogbone end lightly bumps it. I'm kind of glad to see this thread, I'm having a weird knocking sound on hard straight acceleration myself, sounds like a car engine knocking speeding up as I get faster. And a slight clicking on light right and left turns under slight accel during turns.
I haven't torn into the dif yet, so if you figure it out let me know lol.
Eta I had a dished out dif cup do this on my buggy as well. Clicked when turning. The inner dogbone moves in and out while the suspension travels up and down, and makes the crosspin slide in and out under stress.
spookie is offline
Old 01-30-2016, 10:17 PM
Everything was clean, no significant wear on the cups on the differential. The wheels/tires are not rubbing.
I wish I could upload the YouTube link so you could hear it. I think it's the front diff if I was a betting man.
Might tear into it tomorrow.
Thanks,
Joe
mossman2 is offline
Old 01-31-2016, 06:03 AM
spookie's Avatar
MM, just PM me the video link and I'll post it.
spookie is offline
Old 01-31-2016, 04:56 PM
spookie's Avatar
Well I tore mine down today, inspected the pinion and ring and bearings thoroughly, hardly any wear, mesh was awesome. I did find the frt center cvd under the boot dry, so serviced it. Also changed out the complete center dif for another brand new one, just in case as well. Still there, Not as distinctive now, really have to listen for it. I think the future holds a set of buggy difs, so for now I'll live with it. I also replaced all the a arms while I was in there. Hit a chunk of brick recently someone tossed into some grass. Bent a pin and gouged the crap out of one of the arms. Losi's are brutal trucks indeed.
spookie is offline
Old 02-01-2016, 07:45 PM
Video links sent to Spookie, thanks!
Took it out on Sunday and broke a rear cvd in the first 10 minutes. So no more progress on this one. I did read a lot and I am going to focus on shimming the front diff and see if it gets better.
Thanks!
mossman2 is offline
Old 02-01-2016, 07:49 PM
spookie's Avatar
Here you are Mossman, it sounds like ring and pinion skipping to me. I would say rear dif, since it was in a small wheelie when it did this. Mine doesn't sound like this at all. Mine is slower knock. Be careful what you buy to repair this with. When I pulled my frt dif apart is wasn't a 12tooth pinion as expected, but a 10tooth. ;( I forgot to count the ring. A quick way to find out if it's rear or frt, let it rest against you're foot to block it with tires on the ground, then give it light throttle and listen to which dif the noise comes from.
https://www.youtube.com/watch?v=XNci_ymKc_s
+ YouTube Video
https://www.youtube.com/watch?v=RZw6Q9WbvH8
+ YouTube Video
spookie is offline
Old 02-01-2016, 08:06 PM
spookie's Avatar
Thanks!
I am thinking the gas truggy center dogbones will fit in this. I have some on my watch list on Ebay.
http://www.ebay.com/itm/381457329605...%3AMEBIDX%3AIT
I use gas buggy dogbones on all four corners of my 8 buggy. So alot of this stuff interchanges.
spookie is offline
