TLR 8IGHT-E 4.0 Kit Thread! >
Like Tree36Likes
    Hide Wikipost
Old 06-17-2016, 07:39 AM   -   Wikipost
R/C Tech ForumsThread Wiki: TLR 8IGHT-E 4.0 Kit Thread!
Last edit by: Kraig
Welcome to the 8IGHT-E 4.0 Wiki
USEFUL LINKS
Overview
Manual
Pictures
Parts
Print Wikipost
Old 04-11-2016, 12:04 PM
  #361
maddog9's Avatar
Trader Rating: 30 (100%+)
Originally Posted by cHAmpa
What is the part number on these "3.0 stub axles"?
I was working on my son's car these weekend and noticed his front two axles were cracked as well.
Thanks!
Stub axle is losa3522. You will not run the washer or boot with the 3.0 axles.
maddog9 is offline
Old 04-11-2016, 01:10 PM
  #362
Originally Posted by maddog9
I would try 10k in your center diff.
thanks maddog9, that was also one of my ideas what to try next
as well I plan to reduce rear toe in to 2degr. - any thought on this?
as well one of things I find out that this buggy fly`s much higher and longer than my previous one...ok it lands much, much better, but sometimes I do not need such a high or long jump- what setup changes can reduce jump height?
Only ride height or also other tips?
hardijs is offline
Old 04-11-2016, 01:12 PM
  #363
vito's Avatar
vito is offline
Old 04-11-2016, 01:13 PM
  #364
vito's Avatar
vito is offline
  #365
vito's Avatar
vito is offline
Old 04-11-2016, 04:44 PM
  #366
Originally Posted by Slashn77
Anyone care to share their setup for medium to loose grip dirt setup so I have a starting point for my setup??
This worked well for me at our spring shootout. I meant dusty, not wet on the setup sheet
Dont Hack Me is offline
Old 04-12-2016, 03:01 AM
  #367
maddog9's Avatar
Less antisquat will make it not jump as high.
maddog9 is offline
Old 04-12-2016, 07:59 AM
  #368
Trader Rating: 39 (100%+)
Thank you...
cHAmpa is offline
Old 04-12-2016, 12:03 PM
  #369
Ok, but how it will affect steering? I think it will allow to squat car more, so it will make to push front of car even more, right?
hardijs is offline
Old 04-12-2016, 09:04 PM
  #370
Default new body shell
Anybody know of another body shell that is a good fit as apposed to the 4.0e shell?
Cheers
Pegger
pegger is offline
Old 04-13-2016, 05:08 AM
  #371
maddog9's Avatar
It might push more as it will give the rear more traction while on throttle.
If you want more on power steering i would go 0-0 pills for kick up or (starting most frontal) even 1 down and 1 up for the kick up, so the least amount of kick up. Rear hubs all the way back. Thicker front sway bar, thicker rear sway bar. You can try thicker front diff oil, thicker center diff oil. all things according to the TLR tuning guide that will give more on power steering.
Last and most important thing double check your servo savor is tight. If it is loose your overall steering will be terrible.
maddog9 is offline
Old 04-13-2016, 05:37 AM
  #372
Do you guys have a recommended storage case?
KingC0w is offline
Old 04-13-2016, 06:00 AM
  #373
pballer2777's Avatar
Trader Rating: 28 (100%+)
where is the tuning guide found?
pballer2777 is offline
Old 04-13-2016, 06:14 AM
  #374
Cheers
Pegger
I haven't been able to find any other options. I contacted JConcepts, as it looks like Maifield was running one of theirs on his buggy and they said they were working on something but were still 4-6 weeks out from market.
I wish there were more options, I like running different shells and changing up looks.
cHAmpa is offline
Old 04-13-2016, 11:33 AM
  #375
maddog9's Avatar
http://www.tlracing.com/ProdInfo/Fil...uning_Tips.pdf
It doesn't hurt to try some of things to get idea of what it does on your track surface.
maddog9 is offline
