Driving Techniques? Braking
Hi,
I was looking at Short Course Worlds video with Ryan Cavalleri and I didnīt get how to apply this braking techniques in my driving.
Brake all the time, before corners, in corners as well.
Can someone explain how to apply this properly?
Does someone have any video tutorials how to drive?
https://www.youtube.com/watch?v=j0Xwk7vQ9pQ
Hi,
Do you have an link to that video or can I buy it somewhere?
I agree with Cav. However, IMO he doesn't explain it well enough. Braking forces need to match the vehicle's speed, corner type, and traction limitations. A lot of racers will master throttle control, but don't apply not enough brakes (coasting for too long) or apply too much brakes to late causing the buggy to loop out if it's 2wd or understeer if it's 4wd.
There was a great discussion going over on Jason Snyders FB page from Dec 25th after he posted the Cavalieri video.
It got me to realize that I was one of the coasting, stab the brakes, guys.
I dialed in 20% drag brake and was amazed how much it helped my lap times.
I'm still off the pace of the super fast crowd but it really helped me see how important brakes are and how much difference it makes.
I'm able to stay on power longer before a corner and it really brought a lot of steering to my setup. When I want to coast I just stay on power slightly.
Now I just have to learn to use the brakes properly and take some drag brake back out.
What kind of brake percentage do you guys set on your ESC's?
I got this new (to me) Durango DEX210 with Viper VTX10R BE ESC and when I slam on the brakes the car slows rapidly and spins around just before it comes to a stop. There's a braking "noise" that I hear that sounds a lot like dirt pins scraping the asphalt, but I can't quite tell if it's locking the tires. When coming to a stop from a slower speed I can tell it's not locking the tires, but I don't know if it's doing that when stopping from full speed. I don't think it is because I'm not creating any flat spots on the rear tires.
So is it too high to have your brake setting on the ESC at 100%. Is it normal to have that set at something less than 100%?
With more traction you can run slightly higher braking force.
I usually run about 10% drag brake in both.
Iīll tried to find that discussion on Jasons page..
Itīs all about timing and practice.
Itīs always interesting to look at what to practice on.
I went through all the setup sheets on the Orion website for 2wd buggy.
ALL the pro's on there run right about 10% drag brake in 2wd buggy.
It makes sense to me. Goes back to what Cavalieri said. He talked about motocross racing. If your not on the gas you better be on the brakes. No coasting.
Are you talking about drag brake or manual braking. Most pros use 0 drag break but I don't know what most use for brake force. I have. I have mine set for 80 but if your heavy on your trigger control go ahead and lower it to what feels comfortable. If you set it to low it's hard to nose down in jumps.
I also found setup sheets and a Viper programming guide on petitrc.com where it actually recommended never running brakes at 100%.
Thanks for the info guys, and sorry to jack your thread, Torvald.
I was talking about manual braking. And from what I'm seeing here it looks like setting something less than 100% is absolutely normal.
I know I'm learning a lot.
I think 100% would be full lockup. Not good for racing.
