Electric probs. Motor cutting out. >
Old 01-06-2016, 09:42 PM
Default Electric probs. Motor cutting out.
Just bought a car 8.2 tekno v4 conversion. When running 3s the motor cuts to low power then cuts out. Red flashing light on the esc. This happens within seconds. Works fine with 6s.
Lvc is set to 3V. The 3s lipo has 320A burst so it should handle the 211A the motor pulls.
The 6s is two 3s that would never fit in the car to drive, im testing it on the bench as it hasnt been run yet. I bought it as a nearly finished project. All the elecs look brand (as advertised) new and no burnt smell
Team orion R8x esc
LRP Dynamic 8 2200 KV
16/46 gearing.
Overlander tracksport 11.1V 6500mah hardcase
Just orderd a turnigy 4s 5000 with enough mah to run it hope it does. I'm stummped. Think it could be a voltage thing.
andrews81 is offline
Old 01-06-2016, 10:44 PM
My RX8 was doing something like that. Put a small capacitor that you plug into the receiver and it helped. Also check sensor wire
KyJoe340 is offline
Old 01-07-2016, 02:27 AM
Thanks for the advice i'll look into a small capacitor. What size did you use. I dont have the sensor wire plugged in as there is no room.
Old 01-07-2016, 04:25 AM
Might be a lipo low voltage cut off triggering? If the ESC was detecting or set for 4 cells it would trip pretty quick on 3. Suggest trying to set it manually for 3 cells. Remember to switch it back for 6, or 4, etc.
Dave H is offline
Old 02-16-2016, 11:45 AM
Thanks for the advice the esc was detecting the wrong cell count.
