-   Electric Off-Road (https://www.rctech.net/forum/electric-off-road-4/)
-   -   Pinion Gear problem (https://www.rctech.net/forum/electric-off-road/905612-pinion-gear-problem.html)
Sc102wdFun01 12-31-2015 11:27 PM
Pinion Gear problem
I recently purchased a new 14t 48p pinion gear. When I screw in the pinion gear to my motor shaft the screw doesn't go in all the way but it is really tight and won't fall off the shaft. Is this okay or does anybody know what I can do to make it go in all the way
Grizzbob 01-01-2016 03:34 AM
It should be fine, the set screw typically doesn't go all the way into the pinion when it's on the motor's output shaft, just make sure it's on the shaft's flat spot & tightened down good, & it should be just fine....:)
Sc102wdFun01 01-01-2016 07:58 AM
Thanks for the help, much appreciated.
