Mugen Seiki MBX7TR  ECO >
Like Tree4Likes
Old 03-14-2016, 05:35 PM
  #76
nitro2be's Avatar
Originally Posted by CRaZeD View Post
Quick question, does the aluminum servo saver for the mbx7r eco buggy work for the mbx7tr eco truggy? I know its fairly new but didn't see it listed in the compatibility list, thx
YES
nitro2be is offline
Old 03-14-2016, 05:50 PM
  #77
1/8 IC Fan. Has anyone mentioned to you you would gain an advantage with a 2000 kv Truggy motor?
Keith B is offline
Old 03-14-2016, 06:19 PM
  #78
Has any one have a update video off this truggy racing on a track
coombes is offline
Old 03-17-2016, 02:43 PM
  #79
Suspended
Picked up an MBX7T roller for an absurdly cheap price ($120 w/body) that had a broken control arm/a-arm. Replaced all the arms, rock guards, chassis guards, body mounts, and braces for around 60$. I replaced them with the X7R arms instead of the original, any idea if it's worth it to get the updated chassis as well? The steering assembly is super cheap too (8$) and I anticipate getting that as well. Anything else about the R that makes it a better truggy? I guess I'm into it for about $180 so far.....
omgbilly is offline
Old 03-20-2016, 06:44 AM
  #80
1/8 IC Fan's Avatar
Trader Rating: 102 (100%+)
I have been looking at the Truggy Specific Tekin motors, yet have not sprung for one yet. I do want to do a comparison between one of my standard 2000kv "buggy length" motors vs the Truggy ones.
I am not sure yet, as what will be the biggest gain, bottom end and temps? The 7Te has been doing well with a Buggy Motor, but I think perhaps that can be attributed to the LiPo.
1/8 IC Fan is offline
Old 03-20-2016, 06:59 AM
  #81
Its temps the truggy is heavier , and you would have to gear lower if you do decide to run a buggy motor on the truggy , as far as bottom end the truggy motor has more torque and you will notice the difference .
mavdriver is offline
Old 03-20-2016, 08:08 AM
  #82
romanmotruk's Avatar
I was puzzled finished weight of the chassis, and decided to reduce weight by reducing the weight of the motor, and made from the motor Hobbywing Xerun 3656 rewound on 2150 kV
http://rcmaster.com.ua/wp-content/up...2/IMG_1626.jpg
romanmotruk is offline
Old 03-20-2016, 08:30 AM
  #83
1/8 IC Fan's Avatar
Up until now, I have had no issue with the Buggy motors, the LRP Dynamic8 and the Trinity D8 series - the Temps have not reached critical. The ESC's have held up well also (2ea Novak Activ8 v2, 1ea LRP SPX8). I can imagine though that the Tekin Truggy motor will perhaps run cooler, yet, I want to see the Torque and bottom end tractability of the motor when I do try one out. If it gives me better low end tractability, and torque then I will perhaps make the switch to truggy spec motors.
Old 03-20-2016, 01:26 PM
  #84
Does anyone know if I can use under drive gears in the rear of this truggy, as I did with my buggy? If so, are they the same part number as the set for the buggy?
450rdawg is offline
Old 03-24-2016, 03:34 AM
  #85
Was there alot of guesswork in picking a mod 1 pinion for the 46 teeth spur?
Keith B is offline
Old 03-24-2016, 04:55 AM
  #86
werner sline's Avatar
we can't see your pictures
but what did they do in this russian site : put out some copper wire from the motor ?
werner sline is offline
Old 03-24-2016, 05:08 AM
  #87
http://rcmaster.com.ua/wp-content/up...2/IMG_1628.jpg
http://rcmaster.com.ua/wp-content/up...2/IMG_1629.jpg
http://rcmaster.com.ua/hobbywing-xerun-3656-2150kv/
I cut out the old coil, make the heat treatment of the stator and make a new coil with a thicker wire, and more wire and more turns
Old 03-24-2016, 09:14 AM
  #88
1/8 IC Fan's Avatar
When I get home let me double check the Pinion, I believe I am running a 15T right now. I had run the Steel Spur (E0234 46T) on my 7Teco for a while before switching to the (E0256 46T) Plastic Spur.
Old 03-24-2016, 09:42 AM
  #89
Yeah to bad we gotta talk about this in here. What I think is going to happen is me using the 2200 kilovolt that comes with v2 because Tekin and Tenshock are heavy into the truggy motor biz
Keith B is offline
Old 03-24-2016, 01:46 PM
  #90
1/8 IC Fan's Avatar
I verified I am running a 15T pinion (Novak) which puts me right at the minimum available adjustment for gear mesh. I will play around once I have the Tekin Truggy motor in gearing up, and removing some punch from the ESC.
