    Hide Wikipost
Old 08-23-2016, 10:37 AM   -   Wikipost
R/C Tech Forums Thread Wiki: TLR 22 3.0 Race Kit Thread!
Last edit by: Matt Trimmings
Cub86 posted the question: Hi. I'm struggling to understand the lay down situation. I run on high bite damp smooth clay and think the conversation would help on my surface but from what I'm reading I need to buy the lay down kit tlr338004. And the dirt gear case tlr332063. But do I really need both from what I've read the dirt case is 1-2mm higher anyway and u don't use the +3mm hubs or the front pivot hrc or Hrc mod. So is the dirt lay down kit tlr332063 is all that's needed to get me a lay down set up that's suited for clay With the components and car I already have. And if I only get the dirt case is there any problems that will need to be addressed IE.. bone plunge . I do know I'll need 1mm spacers on the waterfall to clear the battery. Thanks guys really trying to get my head around this.
Franks response:
Laydown Conversion will work great by itself. You run the aluminum +3mm hubs, the diff is +3.5mm, and you run the HRC front setup. Just follow a setup sheet from tlracing.com (Frank Root).
Dirt Tranny has the diff at the same height as the standard tranny case, and works with the standard plastic hubs. Both are +/- 0mm from stock. When you run this, no need to run the HRC front mod either.
I've found the stock laydown conversion parts to work great for most tracks. The dirt tranny is a great tuning option, but definitely not 'required'.
K.King
Something I made, pretty basic. Just to give people an idea.
Print Wikipost
Like Tree16Likes
Old 02-27-2017, 08:48 PM   #4366
Motor? I run 28/69 at OCRC and SCVRC w/17.5 Reedy short stack at about 130-140 degrees temp w/50 timing.
MachineAge is offline   Reply With Quote
Old 02-28-2017, 01:26 AM   #4367
Originally Posted by ZEe_NYC View Post
Yessir. Part time. I go when I can.
Also, question for the thread:
my top shaft has play going in and out that is causing a tiny bit of 'noise' in the drivetrain. Solutions? Fix? Normal?
I had some play in my top shaft and shimmed it out. I have been doing this for a while now, and used to shim the top shafts on my AE cars as well. I use Yokomo and Calandra Racing Products shims. I shim just enough to take most of the play out while allowing for free movement once the transmission case halves are fully screwed together.
StadiumRC is offline   Reply With Quote
Old 02-28-2017, 10:00 AM   #4368
I am getting a Trinity d4 tomorrow.
stylezudevil is offline   Reply With Quote
Old 02-28-2017, 06:12 PM   #4369
Trinity D4, and i have 69T spur
Old 02-28-2017, 08:37 PM   #4370
F N CUDA's Avatar
Trader Rating: 31 (100%+)
I run this same gearing and it's right there except with an R1wurks motor.
Craig Hammon
F N CUDA is offline   Reply With Quote
Old 03-01-2017, 07:59 AM   #4371
Trader Rating: 171 (100%+)
What do you think of that motor, and have you done any dyno tuning?? Thinking of picking one up.
We go to have fun, that is why we go
Grand Cities R/C Club member
Ecrt.5 on 4s pack= 82 mph
Ecrt.5 on 6s = broken parts
We stand for our flag!!!!
Troubles Dad is offline   Reply With Quote
Old 03-01-2017, 04:59 PM   #4372
Trader Rating: 24 (100%+)
https://www.facebook.com/16771357659...9024652462901/
Christ follower - I race TLR - Evolution Grafix - Discountrcstore
redbaron is offline   Reply With Quote
Old 03-01-2017, 05:27 PM   #4373
F N CUDA's Avatar
you will not be disappointed
I run R1 servos (may be able to get em again soon )
esc's
motors and
batteries
All are top level equipment, fast is an understatement
Tell em 'cuda sent ya
Craig Hammon
Old 03-01-2017, 05:29 PM   #4374
Originally Posted by redbaron View Post
Looks like a stand up tranny in the opening shot.
TimmE is offline   Reply With Quote
Old 03-01-2017, 05:35 PM   #4375
Trader Rating: 17 (100%+)
Laydown in the second shot.
MX304 is offline   Reply With Quote
Old 03-01-2017, 05:51 PM   #4376
Both versions in one box or two different models?
Old 03-01-2017, 06:21 PM   #4377
Team Pink's Avatar
Trader Rating: 20 (100%+)
All of people's question I'm sure will be answered tomorrow. Based on prior releases I would imagine TLR will be doing a Facebook live feed explaining everything new. Once again, I'm sure TLR has outdone themselves. Can't wait!
Team Losi Racing/ Spektrum/ Horizon Hobby/ JConcepts/ Hobby Star/ Schelle Racing
Team Pink is offline   Reply With Quote
Old 03-01-2017, 06:41 PM   #4378
ALL racers will be happy!!
Randy
RandyJones is offline   Reply With Quote
Old 03-01-2017, 07:45 PM   #4379
No idea. Guess we'll find out tomorrow.
Old 03-01-2017, 10:47 PM   #4380
thecman26's Avatar
Trader Rating: 99 (100%+)
We'll see tomorrow! I am hoping one box.
Chris Keen: Viola, Kansas
Kyosho RZ6, TLR 22 3.0, TLR 4.0 SR (soon),& 22T 3.0
"I'm too drunk to taste this chicken!", Col. Sanders
thecman26 is offline   Reply With Quote
