TLR 22 3.0 Race Kit Thread!
#4351
#4352
Well that was quick.1/10 22 3.0 SPEC-Racer MM 2WD Buggy Race Kit | HorizonHobby
#4353
From what I have heard it will be a new chassis and gearbox at minimum.
#4354
Wow. Sure enough. Like some others have guessed, I think it will be more of a "3.5" update with all the new (common) parts from the SCT/T 3.0 and a revised rear suspension with shocks on the front, etc. Maybe that makes it a 4.0 - who knows. We'll find out in the next weeks/months...
#4356
Missed the boat on the laydown thing. Now it's a hard sell to buy a 3.0 + laydown conversion when everything else out there is far less $$.
Another interesting question, where'd their race team go? Phend is the only 5-star guy left.
#4357
Here is my guess,
New chassis and tranny case, drivetrain stays basically the same so we can use the SR stuff
3.0 truck rear hubs and front spindles
current front end
New Rear arms that are in some of the SR kits with shock holes in front of arms as well as rear.
New suspension hangers and sterring just to make it cost just enough to convert so we have to buy a new car.
current front end
#4358
What is the effect of having more/fewer internal shock limiters? For example, in the 22 3.0, if the front shock stroke is 22mm with 2mmm internal limiters or 22mm stroke without limiters, it's still a 22mm stroke either way. So what effect does having internal limiters have?
#4359
You run at IRH don't you?
#4362
Servo behind mounts
Do you have to use a low profile servo to make this mod work? I tried a regular size servo, but the horn hits the top plate.
#4363
#4364
gearing, start.
Built 22 3.0 and need to decide on gearing. I run on a clay/dirt indoor track, that is rather small (no big stretches at all). What would be a good starting point?
