Old 11-07-2005, 11:20 PM   #1
Default Gearing
I have a MF2 with Masher 2ks, for starters i tried 18/86 and it seemed to have way to much low end power. Do i need to gear up or down, i have 16, 17, 18, 19, 20t pinions only and 82 and 86t spurs.
speed lives is offline   Reply With Quote
Old 11-07-2005, 11:24 PM   #2
Scottmisfits's Avatar
Go up on your pinion. Try the 20. If that's still too much, try the 16/82 combo. Then just keep going up on the pinions from there until it's right.
Bigger pinion is more speed. Bigger the spur is more bottom end.
Scottmisfits is offline   Reply With Quote
Old 11-08-2005, 09:17 AM   #3
Hmm everyone was telling me you would have to gear mashers alot lower? I traded for this truck and it came with 20/86 gearing with normal sized tires and it seem to be pretty good, so you think 20/86 might work with mashers to?
So it goes
bigger t pinion more top end, less low end?
smaller pinion more low end, less top end?
bigger t spur more low end, smaller spur more high end?
Old 11-08-2005, 02:08 PM   #4
Well i guess i will try the 86/20 and go from there im sure i can figure it out.
I got another question though, i bought Tamiya 48 pitch pinions and i tried them today and they don't sound good at all. Sound real ruff and loud, i tried adjusting the motor positioning to try and set the gears better but nothing helped.
Old 11-09-2005, 07:00 AM   #5
Tamiya uses metric pinions and spurs. they do not mesh well with standard pinions and spurs. What motor are you running with your truck. You would gear lower with the mashers as they have a taller sidewall. If running a nice mod motor you should gear it 16-18/86 if running a stocker or 19 turn gear 18-20/82 as the stock motors have more torque then rpm. The MF2 is geared for better accel. over the original xxxt so I could be off by a tooth or so.
The TOYMAN
Team SR Crew
Island Raceway and Hobby
He who doesn't have the most toys can always buy more.
mstng87gt is offline   Reply With Quote
Old 11-09-2005, 11:00 AM   #6
I'm running a Novak ss5800 brushless.
Old 11-09-2005, 11:04 AM   #7
Also what are some good cheap pinions i can pick up at Towers.
Old 11-09-2005, 02:23 PM   #8
Suspended
anything robinson racing or the losi pinions. i like the losi pinions better they are so queit
THE_REAL_FROBOY is offline   Reply With Quote
Old 11-09-2005, 03:13 PM   #9
Alright cool i orderd some losi pinions. I got 16, 17, 18, 19t pinions hopefully that will give me enough options.
Gearing lickashotblaow Electric On-Road 0 07-29-2007 05:47 PM
NeeD Help with gearing please daver1 Electric On-Road 4 07-20-2007 09:12 AM
Gearing for TT-01 tl-01-jhb Rookie Zone 0 11-10-2004 05:35 AM
Need help gearing a TC3 fasda1 Electric On-Road 10 11-06-2004 11:51 AM
Gearing??? mike m Monster Trucks 3 01-24-2004 07:54 PM
