Slow XXXT
Old 11-03-2005, 03:50 PM
Default Slow XXXT
For some reason my XXXT is super slow. I've got a good pack, stock esc, new brushes. Is it possible that the transmission is shot? Is there a way to tell?
Thanks,
Derrick
derrickh_00 is offline
Old 11-03-2005, 03:56 PM
Trixter's Avatar
Set your truck on a car stand or box or anything that lets the wheels roll freely. Take the pinion gear off and rotate the back wheels. If they run very freely then chances that the tranny is OK. I will bet you that the brushes are very dirty (maybe even burned a little). You might need to have the armature turned by someone with a lathe and install new brushes. Check with your Local Hobby Shop, or someone with a lot of experience at the local track
Trixter is offline
Old 11-03-2005, 04:00 PM
I just put in brand new brushes, and it still is just crawling along.
Old 11-03-2005, 04:04 PM
Trixter's Avatar
Please forgive the questions that I ask, but I don't know where you are in your R/C journey. Did you examine the armature, and make sure that it was very clean. Just new brushes with a dirty commutator (the part of the armature that the brushes run on) doesn't help.
Trixter is offline
Old 11-03-2005, 05:08 PM
killer89's Avatar
Trader Rating: 41 (100%+)
cut the comm...
killer89 is offline
Old 11-03-2005, 05:46 PM
Trader Rating: 14 (100%+)
is your diff slipping or your slipper to loose?
if your diff is slipping too much you can cause damage and would require a new diff gear, rings and possibly balls.
o.s. power is offline
Old 11-05-2005, 06:10 AM
Team Duratrax's Avatar
Thanks,
Derrick
Approximately how many runs has the motor been through? I'm guessing that the comm has been worn to the bone. If that's the case, then new brushes will do nothing for you.
Team Duratrax is offline
Old 11-11-2005, 09:38 PM
Registered User
losirunner's Avatar
i i like how this guy just stopped cheking here...
losirunner is offline
Old 03-26-2006, 03:45 PM
Default got busy
Sorry I haven't checked it, been deployed.
Old 03-26-2006, 05:52 PM
That0neguy's Avatar
Just for some background.If he had a xxx-t RTR2 with stock motor...Then the comm cannot be cut, its sealed can.
If this is the case, get a new motor.That one is junk.
That0neguy is offline
