Schumacher's new K2 4wd buggy ..!
#841
Blanks
#842
New Cat L1 is out of the bag!
#844
what price on cat L1 kit ?
#845
The likely shop price in the UK is about £430, which is about $600.
#846
Just looking through the exploded diagram of the CAT L1 and it now shows a U7433 which are blank tapered pistons that should be available
#848
If you can get it for $450, that would be about £325 for us. Quite a big gap I would say.
#849
Hi just bought k2 spur has play??
Have my first k2 great car just checking it over and spur gear has play in it before I strip it will this be the bearings, idle shaft that need replacing?
#851
If anyone still has this car, could you please measure the diameter of the gear diff casing for me? I am building up a 3D printed 4WD buggy that uses Schumacher K1/K2 belts, and was hoping that the diffs would also fit. You can see my project here:
3D Printing a 4WD Buggy
#853
Hey Guys,
Does anyone know if the Cat L1 front wishbones will fit onto a K2? I assume the rears will be fine given the fit on the KC.
Cheers,
Scott
Cheers,
Scott
#854
Compared to the K2 rear wishbones, the L1 pivot pin hole to pivot pin hole length is slightly shorter (~2mm).
Pictures showing the different arms can be viewed in Cruise's L1 build thread at the following link.
Schumacher CAT L1 der UIT
https://www.rcweb.de/index.php/Threa...AT-L1-der-UIT/
#855
Champion!
Thanks very much for taking the time to give such a detailed answer.
