Schumacher's new K2 4wd buggy ..! >
Like Tree27Likes
    Hide Wikipost
Old 08-11-2016, 07:12 AM   -   Wikipost
R/C Tech ForumsThread Wiki: Schumacher's new K2 4wd buggy ..!
Last edit by: AmiSMB
Welcome to the Schumacher K2 Wiki!
Please feel free to add tips and tricks as well as any information that you would feel is beneficial for everyone to know.
Introduction and Pictures Introduction and Pictures
ElectronicsSetupElectronicsSetups
Setup SheetsSetup Sheets
EmulsionShocksEmulsion Shocks
Tony Newland Gear Diff BuildTony Newland Gear Diff Build
Help I Keep Breaking Front Arms
With the K2 Schumacher sarted using an adjustable hub design that required
a relief cut in the arms for the steering knuckle to clear. The easiest solution
until a revised arm is to run the old style arms without the relief cut. Run the
hubs in the High position and set your steering end points down so the steering knuckles don't hit.
SCHU3597
SCHU3407 MED Flex
There is a newer batch of the SCHU3407 wishbones which correct the weakness in the previous front arms.
Suggested upgrades/spares
Strongly suggest to buy 10° alloy front alloy pivot blocks-U3556 the A & B front plastic pivot blocks-U4798 will break soon.
Have some shock seats spares, alloy v1-U3611, plastic-U3937, alloy v2 (off-road)-U4890
Have some spare shock shafts available U3668 & U3669
MIP pucks an Excellent option!
Misc
Other wheels that fit apart from the Schumacher wheels
Losi 22-4 wheels will fit on the front the rears will work as well!
AE b4, b5 & b6 will fit on the rear
Be sure to lock tight the track screws and rear strap this is a must!!!
AE (12mm) and KYO fronts will work with .5mm spacer - available through AVID
Don't buy the purple titanium turnbuckles as an upgrade there thread is too small and they wander too much. Lunsford Super-duty titanium turnbuckles fit very well they are 3.5mm threads. Get the 1 3/4", 2 1/8" & 57mm lengths. I did not replace the Centre Track Rod.
** When running the Super Duty turnbuckles with the stock captured ball ends, be sure to check for binding in the front steering and camber links after each run - tumbles and glances off the pipes cause them to flex and slightly twist and can bind up the front suspension ... The fix? - simply take a turnbuckle wrench and twist the link back and then forward to it's original positon .. consider doing this as a maintenance step after each run ..
Suggested Gearing
5.5 - indoor high bite clay 83/20 (+/- 1 tooth for layout and conditions etc)
6.5
7.5
8.5
9.5
10.5
13.5 At SRS Arizona I ran 75/28 buggy was quick! RCM lockout worked great!
17.5 - FDR between 5-6 depending on track. E.g. 35/66 down to 30/69 slipper eliminator in use. Different options within the thread. I use B5M exotek eliminator and file it to fit.
Print Wikipost
Old 03-15-2017, 06:18 AM
  #736
ROSCOE's Avatar
Trader Rating: 130 (100%+)
Anyone gunning one for 13.5 racing? Any tips?
ROSCOE is offline
Old 03-15-2017, 07:08 AM
  #737
Trader Rating: 33 (97%+)
I recently took 1st for our local club winter series race in the 13.5T Super Stock class with a combination of Michal Orlowski and Larry Myers setups, plus some lightened parts with lighter 2WD front wheels, slipper eliminator, plastic parma pinion and MIP shafts, more info here:
REVIEW: Schumacher CAT K2 - Stadium Trucks & 1/10th Buggies @ URC Forums
see full list of recommended upgrades for 13.5T racing in the OP of the thread.
billdelong is offline
Old 03-20-2017, 11:15 PM
  #738
Mopar's Avatar
Come one, come all! Join us on Facebook in Schumacher RC Nation page. It's a closed group, so just request entry and either Richard or I will accept you.
Mopar is offline
Old 03-21-2017, 08:16 AM
  #739
Why? Facebook is such a horrible way to discuss anything.
scoobyrs25 is offline
Old 03-23-2017, 03:19 AM
  #740
Volition's Avatar
Can you post the link please
Volition is offline
Old 03-23-2017, 06:20 AM
  #741
I've stopped following a bunch of alleged "friends" due to forcing their political beliefs on me... but in general, I find that folks tend to be more courteous when their picture/name are exposed... I see too many trolls on the forums who mask themselves behind an avatar and somehow feel they are above everyone else... I think the day is coming where we will see a shift in social networking on many different levels as various marketing levels mature.
+1
Kinda bummed that they force you to join if you want to see anything on the page:
https://www.facebook.com/groups/schu...ion/?ref=br_rs
Old 04-17-2017, 07:52 PM
  #742
Hey gents, anyone got an SX3 they'd sell?
just_racing_75 is offline
Old 05-05-2017, 10:46 AM
  #743
Default Have SX3
I have a good one. Just refurbed. Is carbon fiber kit. Shocks have new seals. Has the front 10 degree alloy hanger and both rear alloy hangers. Has SV2 rear shock tower and arms (and original). Has always been run with B44 chassis protector. Has the bleeder caps. Belts have two race days with the mid and front being Bando. Is set up for Astro. PM me for my e-mail if interested.
4wdfull is offline
Old 05-23-2017, 04:47 PM
  #744
Thumbs up RC Shox Slipper Delete
New RC Shox slipper delete is available at DiscountRCStore.com 5/26 KC/KD/K2. Excellent unit!
Taz_S likes this.
MelKF2 is offline
Old 05-23-2017, 05:07 PM
  #745
OriginalDonk's Avatar
Trader Rating: 44 (100%+)
How much stress is this going to place on the K2 drive train? Belts gonna be screaming?
OriginalDonk is offline
Old 05-23-2017, 06:04 PM
  #746
JsK
R/C Tech Elite Member
JsK's Avatar
13.5 cars
JsK is offline
Old 05-23-2017, 06:11 PM
  #747
Default Slipper delete
Only used for spec classes 17.5/13.5 Has been tested No issue reported from drivers! Still using mine flawless!!
Taz_S and DiscountRCStore like this.
MelKF2 is offline
Old 06-07-2017, 11:44 PM
  #748
Taz_S's Avatar
From then Wiki you can run TLR22-4 front wheels with out any mods?
Taz_S is offline
Old 06-08-2017, 01:50 AM
  #749
JsK
JsK's Avatar
As long as they don't rub the bearing you should be fine. It really is gonna
on who made the wheel, I have had some that rub and some don't. Be prepared
with some wheel spacers just in case. They have a slightly narrower offset than
the Schumacher wheels, about 1mm per side.
Anytime you use any other wheels there is a chance the hex will be to deep and they will
rub. Keep some of these around.https://www.amainhobbies.com/schumac...hu4321/p260374
Pretty much every company that makes a T/C has these so there pretty easy to find.
JsK is offline
Old 06-09-2017, 07:56 AM
  #750
Taz_S's Avatar
As any one try the
Schumacher U7139 - Wide Rear Pivot Conversion - CAT K2
on dirt yet. I going to be on a med to high bit clay.
Taz_S is offline
